Thread: Help please no power to injectors
    lincoln
    Default Help please no power to injectors
    Hi i have a cdti it wont start done several checks & now found the injectors are'nt turning on fuel is fine & pressure/ power for rail ok just no power at injectors any help please i have also tried different keys as it like an immobiliser fault theres no faults showing on tech 2 either thanks
    Regular Member muffking's Avatar
    Are you sure it's the injectors that have no power and not the glow plugs as the injectors get their power from the ECU, so it would be unusual for Tech 2 not to pick up on them.
    The glow plugs just get their supply via a relay off the ECU, which is probably fused anyway.
    .. Just spotted you're in Lincoln too, shame mie's a petrol.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Injectors don't work with an 12V on/off signal. What equipment have you used to come to the comclusion that the injectors aren't turning 'on'?
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Quote Originally Posted by Ste View Post
    He used a light tester in plug. (from another thread)
    I wouldn't rely on that test as the injectors are pulsed, so a light tester would not light up properly, if at all. Also the tester should be 5V.
    Ideally to test the plugs an Oscilloscope should be used, but Tech2 should still pick them up as a problem if they don't fire.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    A bulb won't work, as the pulsed signal is far too short to light it.
    Either a scilli or a good coil clamp may detect the electrical pulse that fires the injector
    Feb 2007
    Glasgow
    Without any more info, it's hard to say, but the test lights could have been noid lights...
    http://www.pvrdirect.co.uk/productin...s&catref=VS213
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    More info needed.
    Nico, I've just thought, if you can get it to "Expert Test & Tune" on Deacon Road then they can fix it as that's where all the dealer cars go that the dealers can't fix.
  1. 2.0t injectors
    By mann3210 in forum General Motoring Chat
    Last Post: 1st January 2012, 15:27
  2. Injectors?
    By BigWilko in forum Engine & Drivetrain
    Last Post: 14th June 2011, 20:27
  3. injectors
    By damo-SRI-T in forum Petrol Engine related
    Last Post: 9th June 2011, 08:02
  4. Injectors? help
    By Ean in forum The 'Off Topic' room
    Last Post: 26th October 2009, 12:56
  5. injectors reprogrammed = more power?
    By marky2027 in forum Vectra C / Signum Car Chat
    Last Post: 23rd November 2007, 13:42
vectra c injector signal
opel vectro not supplying power to enjectors.
vectra c injector no injector signal
vectra c no power at injectors
no power to injectors opel
How many injectors have power at tbc in petrol engine
cdti-no power to injectors 2 & 3
no power to injector opel
opel rekord no power on injectors
