Thread: cooling fan probs
    sheffield
    Default cooling fan probs
    Hi all. still no joy with the gear changing. I'm now thinking there may be a fault with the cooling fans as when temp goes high, gear changing becomes impossible....possibly due to fluid getting too hot. The cooling fans do not seem to come on when temp high, infact i've not noticed them come on at all. I have connected a direct power source to the fans and they work fine. Does anyone know what controls the cooling fans operation when temp goes high??
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    normally a sender unit in the side of the radiator controls the fans
    sheffield
    thanx.
    May 2006
    scotland
    As an experiment, can you not do a temp. trial and have a direct source to the fans at all times when ignition is on (so they run all the time). Then if you do not get a gear change problem, your theory is most probably correct i.e. it is temperature related?
    is it a manual or an automatic gearbox??...
    if it's a manual then the cars radiator doesn't cool the gearbox oil anyway...it's self contained.. If it's an auto then yes, there is a small cooler on the end of the radiator..the fans are controlled by a unit that will be screwed to the fan's sheild..there is no temp sensor on the rad, it runs off the engine's sender unit..
    sheffield
    its a manual. If I was to constantly keep the cooling fans running via a direct source of power at all times, can this cause damage to the engine??
    not to the engine, but it won't help your gearbox at all..total red herring...
    if you have a tight gearbox the best you can do is drain and refill it.... the fact it only happens when the temp goes high tells me the thermal load on the oil is too great and it's shearing...in effect no longer providing the lubrication the box needs..
    Concentrate on the gearbox.. forget any engine cooling related thoughts..
    sheffield
    thanx buddy.
    sheffield
    does anyone know if the clutch fluid pipes run behind the coolng fans??
  1. Cooling Fan not working?
    By joegingell in forum Engine & Drivetrain
    Last Post: 3rd June 2012, 11:54
  2. How to test Cooling Fan
    By stevie16v in forum Engine & Drivetrain
    Last Post: 16th March 2012, 18:16
  3. Cooling fan
    By nokiaman1978 in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd October 2011, 19:27
  4. some probs cooling system
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2010, 18:00
  5. Cooling fan
    By Marc 100 in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2008, 00:01
