Results 1 to 3 of 3
Thread: Changing Sidelights - I failed miserably !
    Regular Member MrLOL's Avatar
    Wakefield, West Yorks
    Default Changing Sidelights - I failed miserably !
    So i decided to try the right hand one first. Removed the battery cover and the washer bottle filler neck. Got myself a small torch down in the hole and had a look around. I can find the main beam bulb, and unlocked the mechanism to remove the bulb.
    Trouble is, the sidelight bulb is squashed up against the metal mechanism for the main beam bulb. I can feel the two bits of plastic that squash in, but i cant get a good purchase on it. Ive tryed pulling, but im only touching it with my finger tips so nothing happens. Ive tryed pulling at the wire, but there still seems to be some resistance even when im pushing both bits in
    What am i doing wrong ?
    Maida Vale
    Grip the bulb holder and pull it firmly, nothing else is required. I've found it helps to be crouching down looking at the bulb from the front of the h/lamp, that way I can sure that I'm holding the right bulb.
    Regular Member johnnyg's Avatar
    May 2007
    manchester
    get a pair off long nose plyers dead easy with them mate 2 seconds of a job.take the air box partly out for the drivers side
  1. drl sidelights
    By andy_richmond in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2012, 17:41
  2. sidelights
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 3rd December 2011, 17:02
  3. led sidelights
    By neverlandandy in forum Electrical & ICE (including SatNav)
    Last Post: 15th March 2011, 22:47
  4. Turbo Technics fail miserably
    By nutron in forum Diesel Engine related
    Last Post: 9th January 2011, 01:36
  5. Sidelights
    By st2malo in forum Electrical & ICE (including SatNav)
    Last Post: 1st January 2011, 16:40
