Thread: TC Switch questions (not the usual kind)
    Regular Member Whippy's Avatar
    Oct 2007
    wirral
    Default TC Switch questions (not the usual kind)
    i've got a few TC Switch questions. but not the usual kind.
    i know i can't have it!
    first off, i'm assuming but can someone confirm, is the switch a momentary switch?
    eg, press without it locking down.
    second, when fitted, what holds the switch in place?
    does the wiring connector hold it or does the console hold it in place and stop if falling out?
    i've got no wiring behind my TC switch but i do have wiring behind every other blank.
    i was thinking of filling up the dash as it looks a bit boring.
    i've also had a crazy thought about a use for the TC switch.
    also, does anyone have a pic of a fully filled out console.
    ta.
    Regular Member Baz07's Avatar
    Lancashire
    Here you go
    Oct 2006
    Wellingborough
    It's held in by clips on the side of switch (presuming its the same as the park pilot switch) and it is momentary.
    What's your idea? i'd like to see someone with a NOS kit use the sport switch for activation...
    Oct 2007
    wirral
    thanks peeps.
    Quote Originally Posted by Flaninacupboard View Post
    just looking for a switch that doesn't stick out screaming "push me" and is easily accessible.
    should be easy enough if you knock up your own connector.
    *edit*
    looks like it's the sports switch that has no wiring behind it.
    so i'll be looking for one of those then.....
  1. The Usual Problem
    By dontsnatch in forum Vectra C / Signum Troubleshooting
    Last Post: 9th December 2012, 18:30
  2. the usual q's
    By jays_225 in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2011, 17:49
  3. obsession or usual?
    By S14RRJ in forum The 'Off Topic' room
    Last Post: 20th April 2008, 16:10
  4. are these usual problems?
    By tonypc1 in forum Engine & Drivetrain
    Last Post: 11th July 2007, 19:49
  5. Not the usual mpg
    By simon5800 in forum General Chat
    Last Post: 20th June 2007, 16:21
