Thread: more problems
    belfast
    Default more problems
    after cleaning egr valve today. i was looking down at ner where the heater plugs there is a long metal bar off what is that for
    belfast
    Feb 2006
    Kilmarnock
    Hi,
    Have a look at this thread, could it be this.
    http://forum.vectra-c.com/showthread.php?t=33511
    belfast
    what problems do this bar cause because my car is smokey could someone
    explain what this bar does cheers
    Administrator plasma's Avatar
    On the Forum
    404 Post(s)
    Engine : 150
    Mileage : 74000
    That bar is controlled by a motor on number 3 cylinder swirl valve to control the others. The idea behind it is that at low revs it closes off or opens (cant remember which way round it is now) one of the two air inlet valves thus making it more effiencient at low speed. As rpm/speed rises this opens or closes (again cant remember which way) to increase better running..
    Thread mentioned above will explain how to fix it. But these valves can coke up and cause them to stick open/shut
    Whilst mine was knackered i did notice more smoke than usual but after a complete inlet manifold change of this (due to revised design of components) and a cleanup on the EGR valve all smoke was gone.
    Symptons would be bad idle possibly and/or poor performance below 2000rpm.. take that only as a guide line. I've got one i'm looking at tomorrow with the bar off but feels quite fine to drive.
    belfast
    thanks plasma
  1. z18xer vvti, problems, problems
    By gstore in forum Engine & Drivetrain
    Last Post: 20th April 2012, 13:33
  2. 1.8 vvti problems, problems problems!!!
    By gstore in forum Petrol Engine related
    Last Post: 3rd March 2012, 01:31
  3. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 2nd October 2011, 21:20
  4. GSi problems
    By Piemyster in forum Engine & Drivetrain
    Last Post: 27th July 2011, 20:11
  5. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
