Thread: Help - Valve Caps
    Regular Member siross's Avatar
    Oct 2007
    Default Help - Valve Caps
    Hey guys,
    I've just been to top up my tyres.
    I have locking valve caps but when I went to unscrew with the alan key, it just spun round. Looks like the thread is knackered, ****** cheap things.
    Any ideas on how to get them off?
    Simon
    Regular Member MattW's Avatar
    Sheffield
    You may need to have all 4 tyres re-valved.
    Regular Member caledonia's Avatar
    Scotland
    If you think there knackered and are going to replace them why not try mole grips on them, could also try mole grips with a cloth to try and save them...
    VOTING UKIP IN AVELEY
    6 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    i,ll send you round the thieving BARSTEWARDS that nicked my locking ones last night ...they had a little trouble cos they manage to marked the alloys pretty deep
    Regular Member PeteRs's Avatar
    here or there
    must be catching some scrotes removed mine thurs night going back to normal ones now fed up with buying them
    Full Member Big Sig's Avatar
    Hole the stem with some pump pliers and use an adjustable. Worst thing that happens is you need them re valved. Thats what I had to do once and no problems
    Jun 2007
    Black Country
    why people bother with locking ones are a mystery........ you put a metal bolt (tyre valve) into a metal nut (valve cover) and wonder why they stick??
    you either have to put copper grease on the valve thread to stop the caps sticking, and then they get nicked with ease, or you put them on and tighten them up so they dont get nicked, and then you cant take them off yourself
    you need some grips on the tyre valve and one on the cap to remove them, then sling them and stick with the bog standard ones, less hassle and cheaper to replace
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    I have the Richbrook spinning caps in black and I keep seeing finger marks around them but as to now they are still on
    Oct 2007
    Apparently they are good ones, but still didn't work well.
    Managed to get all but one off and doused it in WD40 so will try again 2morow.
    Cheers guys
  1. What valve caps have you got...
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2009, 16:49
  2. Valve Caps Stuck on....
    By signum_1.9 in forum Suspension, Wheels & Brakes
    Last Post: 23rd February 2009, 10:45
  3. Valve caps
    By ghostrider in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2008, 19:35
