Results 1 to 10 of 15
Thread: uprated rear brakes..
    Regular Member hagga's Avatar
    kingswinford
    Default uprated rear brakes..
    morning peeps..the other day ordered new brakes from hi-spec..they now tell me they don't do a rear conversion(but they did the other day!) not wanting to stay with piddley set up on the back..what are my options? VXR rear set up?...or does anyone do an aftermarket rear set up?..or just ebc the back end..
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    arent the vxr the same size on the rear as the gsi? didnt think you could go bigger than 292mm other than aftermarket setup?
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    you can get 314mm and 345mm is the biggest for the front
    292mm is the biggest for the rear try lmf as the do them, and this it is what the gsi have as the rear discs are vented
    kingswinford
    Quote Originally Posted by vectragsi3.2 View Post
    not sure what what the sizes are?...and unsure about if there are any aftermarket ones available...the other day hi-spec said they could do a 325mm rear..but now say they can't..will be speaking to them later this morning.
    kingswinford
    Quote Originally Posted by glynn View Post
    I'm preferably after after market stuff..looking at 360mm 6 pot setup up front..if 292 rear are the largest then I already have them.
    kingswinford
    just spoke to them..and they said they are doing a kit for the rear?? wish they make their minds up going down there tuesday to have caliper clearance checked etc so will soon find out..
    Cambridgeshire
    So on a standard SRI what is the front and rear disc sizes? I am looking at getting the 314mm brakes conversion kit from LMF and they say you get 4 discs, calipers, pads etc... So what size do you get for the rear?
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    A 4 disk front brake conversion - I bet that stops
    Cambridgeshire
    I ment 2 lol.
    So when you do the 314mm upgrade you only do the fronts
    Can you get any bigger for the rears?
    Mar 2007
    Southport
    Quote Originally Posted by parsco View Post
    I ment 2 lol.
    You can get bigger back brakes but it's an expensive cosmetic exercise as the back brakes do very little work, so you're unlikely to notice much difference. The 314mm front upgrade is well worth the money though & makse a HUGE difference.
  1. Uprated Rear ARB For Vectra C
    By Harvey Smith in forum Suspension, Wheels & Brakes
    Last Post: 5th January 2012, 13:44
  2. Uprated Rear ARB??
    By Kev_G in forum Suspension, Wheels & Brakes
    Last Post: 26th January 2011, 19:42
  3. Uprated Sports Suspention (Rear Shocks)
    By scottymf in forum Suspension, Wheels & Brakes
    Last Post: 15th July 2010, 22:27
  4. uprated brakes..front/rear biasing?
    By hagga in forum Handling & Braking
    Last Post: 8th October 2008, 15:08
  5. Replies: 24
    Last Post: 17th February 2008, 13:20
