Results 1 to 2 of 2
Thread: 1.9 cdti clutch noise?
    Regular Member joe2187's Avatar
    Chorley, Lancashire
    Default 1.9 cdti clutch noise?
    I've had the car for a week now & today the clutch started making a grinding noise when pressed half way down. Was not in gear or anything. Just half way down at the biting point it started making a grinding noise, when pressed all the way down there was no noise, when the clutch was not pressed it made no noise, just half way down it grinds. Anyone know what this is? & how much it would cost to put right or if its covered on warranty.
    any geartrain problem except the clutch lining is covered under warranty..... so drop it in to the dealer....
    sounds like either the release bearing or the friction plate is low... my money is on the release bearing cylinder...
  1. Clutch / Gearbox noise / rattle CDTi 150
    By Paul_B in forum Engine & Drivetrain
    Last Post: 1st March 2013, 17:21
  2. vectra cdti noise on clutch
    By hitcho in forum Engine & Drivetrain
    Last Post: 11th July 2011, 00:01
  3. CDTI 150 Clutch noise. DIagnosis required
    By 12345 in forum Engine & Drivetrain
    Last Post: 6th May 2009, 18:35
  4. Clutch noise?
    By aerodynamic18 in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2009, 18:20
  5. 05 Plate - 150 CDTi Clutch Noise
    By iRocco in forum Engine & Drivetrain
    Last Post: 23rd August 2008, 17:25
