Thread: problems
    belfast
    Default problems
    warning light on again .got codes read.(heated oxgen sensor bank1) &
    (egr valve)
    how much is this going to cost now
    just clean the egr valve.....it's far easier than having to shell out for a new one....
    you may well find the lambda sensor fault will go to.. if it doesn't..the sensor is only £70..
    belfast
    am just off the phone to vauxhall 138 +vat for the lambda sensor
    flippin eck...
    they aren't that over here trade..
    belfast
    could u send me one over then
    clean the EGR first and reset the ecu's.... you may find you don't need one at all.......
    belfast
    will do that now carb cleaner ok to use
    carb cleaner and a soft brush will be fine.... make sure the spindle inside is fre to move..
    belfast
    is this the egr Attachment 12913 thanks for the help
    it sure is.......you can see the retaining bolts by your hand..
  1. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 12th November 2019, 09:21
  2. z18xer vvti, problems, problems
    By gstore in forum Engine & Drivetrain
    Last Post: 20th April 2012, 13:33
  3. 1.8 vvti problems, problems problems!!!
    By gstore in forum Petrol Engine related
    Last Post: 3rd March 2012, 01:31
  4. GSi problems
    By Piemyster in forum Engine & Drivetrain
    Last Post: 27th July 2011, 20:11
  5. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
