Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Factory Bluetooth Control Module
    SUFFOLK
    Default Factory Bluetooth Control Module
    For those who have the factory fix CD70 phone bluetooth module fitted, any ideas where it is physically located in the car?
    The TIS/wiring diagram information I've got is a little vague on this point. Assume its somewhere behind the glove box or passenger footwell transmission tunnel?
    I'm not expecting the car to have the wiring plug fitted but starter for ten is working out where the parts need to go. Oddly the headlining has the factory fit microphone plug on the interior light harness which I wasn't expecting, so there may be some how of having the control unit plug as well.
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    It goes behind the oddment tray just below the heater controls. The mounting bracket for it is part number 13188437, it retails at about £3.
    You will need to buy the wiring repair kit to get the plug for the control module. That retails at around £30. You will then have to make the harness up.
    hth,
    Paul.
    SUFFOLK
    Thanks Paul.
    Explains why I couldn't find the mounting points. For some strange reason TIS gives the impression it lives behind the passenger airbag. Under the radio makes a bit more sense.
    Already have the parts, except the wiring bits and bobs so will have to pull the car apart at the weekend and see what plugs etc I have or haven't got.
    A big help,
    Dieselvec1
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    Quote Originally Posted by dieselvec1 View Post
    Thanks Paul.
    A big help,
    Dieselvec1
    I think you will find that TIS refers to the old style factory telephone wiring. All you will be concerned about is:-
    1. Roof microphone ( wiring should be already present). Part number 13255447.
    2. Bluetooth control unit. Part number 13252891.
    You will have to order the wiring repair kit to get the plug for the control unit. You will also need wiring to make the loom up.
    Tech2 to program steering control, colour display and control unit.
    Wirral / ellesmere port
    10 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    and the wiring repair kit aint easy to make up unless ya good and can work
    out wiring diagrams.tis will show you both the pre facelift and the facelift
    wiring setup but however the bluetooth will also work on pre facelift
    although its wired differently,ive retro fitted 2 pre-facelifts and 4 facelifts
    and all have worked perfectly,its just wether you have the relevant wiring
    already present but then it can easily be retro fitted.
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    Dieselvec1 is the man to do it Andy. He as good as you with TIS and the wiring.
    SUFFOLK
    Got to agree with that, Andy is the resident expert on this. Holding the Andy option in reserve.
    First job is to get access to the wiring harness and see what is present or missing and go from there. TPMS seemed to go ok last month, once the dealer got the hang of the programming (Give the dealer their dues, they did manage it).
    Depending on how the Bluettoth goes, I'm still toying with the idea of fitting the electic seats including the DSM and aircon fans but still on the hunt for a donor cars for some of the mechanical seat parts.
    Admin plasma's Avatar
    On the Forum
    311 Post(s)
    Engine : 150
    Mileage : 74000
    I think theres a tradeoff with the aircon fans... cant remember what you lose or whats different.. Something to do with a different type of seat motors possible?
    SCOTLAND
    cheers for the part numbers for those. I might order the microphone to try with my pioneer head unit as i want a more factory look for it.
    Regular Member mel's Avatar
    tayside
    how do you know if your cd70 has this function?????????????
  1. UHP Factory Bluetooth
    By millard2004 in forum Electrical & ICE (including SatNav)
    Last Post: 21st October 2012, 22:02
  2. anyone with factory bluetooth???
    By vectragsi3.2 in forum Vectra C / Signum Car Chat
    Last Post: 27th May 2010, 14:06
  3. Factory Bluetooth
    By paulhb in forum Vectra C / Signum Car Chat
    Last Post: 1st November 2009, 00:09
  4. Factory Bluetooth
    By leeds vectra in forum Vectra C / Signum Car Chat
    Last Post: 10th October 2006, 22:46
vectra c bluetooth module
