Thread: Spark plug change on 2.2
    Regular Member old cruiser's Avatar
    slough
    Default Spark plug change on 2.2
    A short while ago I cleaned out throttle body, EGR Valve , changed air filter, fuel filter and spark plugs, all were in a bit of a state to be honest apart from the throttle body which was surprisingly clean! anyway what I noticed was, when fitting the coil pack back on after fitting plugs, there didn't seem to be a real way of ensuring that the long rubber plug caps (if you know what I mean) were actually clipping on to the plugs as it were, just had to rely on doing up the four bolts and hoping for proper connection on to the plugs, however the car runs fine, has anyone else found/ noticed this when changing the plugs?
    Cheers Pete
    it is a bit vague..but i've never had one that didn't line up..
    slough
    Vague is definately the word , expected to hear/feel them clipping on as you push down on the coil pack, like you would with the old ht cap business, suspect there could well be an air gap between insert in the rubber and the plug on occasions.
    Cheers Pete
    London
    first post here...
    when i changed the plugs in my one few days ago i was thinking the same thing. but when I started the car it did, so i assume it all went well?
    slough
    Quote Originally Posted by ApophisXP View Post
    first post here...
    Hi mate and welcome to the site. Yes mine also started up ok , had a 2001 Omega before and that had a similar setup , but the rubbers were of a more solid kind and you could definatly feel that coilpack clipping onto the plugs; it's probably Vx (and other manufacturers) cutting corners again somewhere no doubt!!
    Cheers Pete
    newcastle upon tyne
    Sometimes the rubber things split at the end and the dealers wont sell them seperately. I have 3 spare rubber plungers for £35 each.
  1. spark plug change.
    By paz_badboy4life in forum Engine & Drivetrain
    Last Post: 3rd October 2011, 01:31
  2. Spark plug change help
    By Lee_gsi in forum Vectra C / Signum Car Chat
    Last Post: 29th July 2011, 15:12
  3. Spark Plug change
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2011, 10:54
  4. 3.2 V6 Spark plug change
    By korlinski in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2007, 14:19
  5. 3.2 Spark Plug Change Help
    Last Post: 11th May 2007, 14:29
How to change spark plugs on a vauxhall vectra 2.2 show me how
how to change spark plugs on a vauxhall vectra c 2.2
vectra c spark plug change
