Thread: signum v6 CDTI power steering
    Deepest Norfolk
    Default signum v6 CDTI power steering
    Hi
    I've owned the above car for about 3 months and am generally very pleased with it, however it seems to have a strange fault with the power steering. Occasionally the power steering feels as if it isn't working! The car will be very heavy to move about at low speeds. I have had the power steering warning light come on once and have had the codes read. They related to failure to communicate between the cambus (is that right?) and the power steering and also another one about the ABS and the steering angle sensor. Both have been cleared but I still very occasionally feel the steering go very heavy( no warning lights have re appaeared so far) and always when I'm just setting off from a junction etc and the steering wheel is being turned.
    Any thoughts anyone, any input gratefully received.
    Tony
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    Could be the pump with an intermittent fault... I'd get that checked out.. mine went the same way.. got it changed under warrenty... but that would be my 1st guess... or possibly the CIM but im not too sure on that. HTH
    EDIT: Here is my 2nd post with a link to my original post inside. When i had my fault.
    http://forum.vectra-c.com/showthread.php?t=56730
    Norwich
    Does sound pump related to me. Ask the garage to look at it again unless its hartwell's, wouldn't trust them as far as I could throw them.
    Plymouth
    I've had a similar problem with the power steering cutting out completely at low speeds (Vectra 04Reg 3.0CDTi) as has my father on his 06 1.8 Vectra. Especially when the revs are slowing down.
    I reckon its the pump cuts out with a lack of engine revs. However it has not done it for a while. Thank god its only at low speeds.
    Turning the engine off and re-starting the engine solves the problem.
    Regular Member oldmanmille's Avatar
    Cheshire
    Default Power steering Issues
    I have the 'steering wheel with exclamation' icon now up permanently along with the traction control light on, again permanently. Took it to my friends garage who attached a code reader.
    it is coming up with both linked and related it to angle sensor. Been told I need a replacement steering unit.
    Anyone else had this problem and what was your outcome along with estimated cost?
    If it is too expensive then i am just going to lay the car up in the drive and SORN it as is used as a 3rd car anyway!
    Thanks in advance...John
    ps: its a 2005 V6 CDTi Vectra
    Deepest Norfolk
    Hi All
    Well I have finally got the problem sorted and solved. Firstly the power steering reservoir was low on fluid so that was topped up but the car still showed the steering wheel fault light as well as the tcs/esp light (intermittently). The car had to go to large main dealers in Beccles where it had to have a "car pass code" issued. I was told it was a code that vauxhall issue to allow deeper interrogation of the ecu's (cost £20). Then a long time on diagnostics and wiring tracing. Finally the fault was traced to a faulty park pilot control unit.
    Anyway the unit was replaced under warranty and so far the car has been fine, total cost nearly £600 pounds!!!! The worst part of all this was the fact that all the diagnostics were not covered by the warranty, so I had to shell out £330 of my own money.
    Hopefully thats the last I shall have to spend on it, apart from servicing, for a long time.
    Tony
    Good its fixed but the first I have seen about anyone paying for the dignostics not being covered. Sounds totally wrong
    Northampton
    Engine : A20DTH
    Mileage : 88000
    No charge for diagostics when the fault involves a warranty claim, you have been ripped mate. Get you money back
    Deepest Norfolk
    Hi All
    In answer to the first comments, I too thought that the diagnostics would be covered. However there is a specific clause in the mechanical breakdown warranty, that states that diagnostics and testing are specifically excluded from the warranty.
    The second part is that I have (as usual ) spoken too soon. The car behaved perfectly for the last week, but guess what, its just started doing exactly the same again. The problem is only showing up when the car is stationary after a run. The steering wheel warning icon comes on together with the esp/tcs light.
    The car is going in again this weekend, and this time I am not paying for any more diagnostics as they have obviously not repaired it from the last time. I will let you know how I get on.
    Tony
  1. where to top up power steering fluid 3.0 signum
    By shaun.b in forum Engine & Drivetrain
    Last Post: 30th November 2012, 15:00
  2. Power Steering Issues - 3.0 v6 cdti
    By larann in forum Engine & Drivetrain
    Last Post: 2nd July 2012, 23:08
  3. Power Steering Fluid cdti
    By Diesel Dude in forum Suspension, Wheels & Brakes
    Last Post: 31st January 2011, 22:32
  4. Signum cdti 150 power steering problem...
    By mr-s in forum Vectra C / Signum Troubleshooting
    Last Post: 28th November 2009, 12:11
  5. power steering on my signum
    By Martybhoy in forum Suspension, Wheels & Brakes
    Last Post: 4th February 2009, 13:00
https:www.vectra-c.comforumshowthread.php59476-signum-v6-CDTI-power-steering
opel vectra 3.0 cdti steering angle sensor calibration
signum power steering fault
power steering fluid vectra v6 cdti
3.0 cdti vauxhall power steering fault on off
vectra 3.0 cdti steering stops suddenly
signum power steering problem
vectra 3.0 cdti power steering
vectra 3.0 v6 diesel heavy steering
vectra 3.0 cdti steering heavy
vectra c power steering hard when air con running
vectra c power steering not working
vectra c power steering problem
vectra c servo pump esp light
where can i locate power steering in signum opel engine
3.0 cdti power steering fault
vectra c v6 cdti power steering problem
