Results 1 to 10 of 16
Thread: Lumpy pickup 1.9 CDTi SRi 150
    Aberdare
    Default Lumpy pickup 1.9 CDTi SRi 150
    Hi - bought an 08 plate Vectra SRi 150 a couple of weeks ago, I'm notincing a possible problem, when driving along in 3rd, 4th or sometimes 5th back off the accelerator coast and when I put my foot down again the car sort of jerks before accelerating?
    If the revs and conditions are just right the car jerks and then takes a second to respond? is this something to do with the fuel shut off (economy) ?
    Is it normal for the 1.9 150 to do this? any help before I go to main dealer would be great!
    Thanks.
    Belfast
    Mine does it too, always did. Probably the fuel pressure drops and doesn't come back quick enough.
    member of the smoke patrol 230bhp+
    what revs are you at when thins is happening
    Aberdare
    Thanks for the reply - the revs are about 2200 to 2500rpm in 3rd or 4th it's most noticeable, feels like a sudden jerk and then a second before the power comes on?
    Belfast
    Yeah, about the same as mine, in 5th about 60-70mph coasting down a big motorway hill (3 miles maybe), then hit the gas at the bottom and the car actually slows down before speeding up again. It's not so bad in 6th as the revs are a bit lower (1800rpm @ 70 in 6th on the Astra).
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    Quote Originally Posted by Jon Richards View Post
    Similiar to mine before they replaced the EGR valve, Its been fine since.
    Aberdare
    Hmm, EGR valve possibly needs replacing then? My car has only done 15k but it just doesn't seem quite right. No warning lights on the dash yet though.
    Can the EGR valve be cleaned at all? Anyone know if this is a common problem with the Vectra?
    Thanks again for all the advise.
    Apr 2008
    In UK
    There are some How-2's on the site giving details how to clean the EGR valve, not that I've done it myself.
    I assume its under warranty and if so I would get the dealer to have a look at it, which is what I did for virtually the same symptoms, I didn't have any warning lights on either. I think I had about 25K miles on mine at the time, when I picked it up they just said it was the EGR valve and had replaced it, certainly resolved the problem I was getting.
    Problem is...d/engines are getting so complex these days with all the emission control bits they have added its often easier to let the dealer sort it out, especially if its under warranty, assuming you can find a good dealer that is.
    Regular Member Andy17899's Avatar
    Jun 2007
    West Midlands
    Vehicle : Vauxhall Vectra SRI XPII
    Mileage : 68K
    I might try this next, is it easy to clean the egr valve? Baring in mind im th emost untechincal person known to man?
    Anyone have a link to this how2? Couldnt find it in the How2 section but only had a quick glance
    Aberdare
    Will take it to main dealer for sure. It's only 7 months old, though I only bought it 2 weeks ago it should be under warranty I guess.
    Found a thread for the EGR valve cleaning under -
    how to clean z19 egr valve (proper method)
    Great photos and looks quite easy. Though I'll try the warranty before fiddling!
    Cheers.
  1. sri cdti 150 lumpy idle/ low mpg?
    By stevesri in forum Vectra C / Signum Car Chat
    Last Post: 10th February 2013, 20:39
  2. lumpy 3.0 v6 cdti
    By Guss in forum Y & Z30DT Specific
    Last Post: 13th September 2011, 11:13
  3. Running VERY lumpy 1.9 cdti 150
    By kevcdti in forum Engine & Drivetrain
    Last Post: 9th June 2011, 08:33
  4. cdti running really lumpy and no power??
    By richiem in forum Engine & Drivetrain
    Last Post: 7th July 2010, 19:16
  5. 1.9 CDTi (150) with no turbo and lumpy revs
    By Robsey in forum Engine & Drivetrain
    Last Post: 3rd December 2009, 00:10
vectra c 1.9 cdti sri running lumpy
cdti runs lumpy 1800rpm
vauxhall vectra c sri running very lumpy
