Thread: signum 2.2dti egr valve cleaning!
    Bedford
    Default signum 2.2dti egr valve cleaning!
    I have a siggy 2.2dti,i want to clean the egr system but the 10000k boost cleaner is too expensive!!!!!
    i have been told that you can use carb cleaner instead,is this true?
    can you spray the carb cleaner directly into the inlet (after the afm)? will this cause any damage??
    you can use carb cleaner.. BUT. you need to remove the EGR valve from the car to do it.. that powerfoam 10000K won't clean the EGR either..you'll need to strip it off the car......
    Bedford
    Thanks mark,will try it tomoz!!!!!!!!!!!
    p.s. Love your pic of your veccy!
    LOL, the signature pic is quite old....abouit 3 yrs out of date.. the profile pic is quite recent thou..
  1. Help cleaning EGR valve!
    By Vectra_Power in forum Diesel Engine related
    Last Post: 23rd November 2009, 10:28
  2. Iac Valve Cleaning 2.2dti
    By cosmic in forum Vectra C / Signum Car Chat
    Last Post: 11th October 2006, 03:40
  3. Is the 2.2Dti an 8 valve or 16
    By 111 in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2006, 18:50
vectra c 2.2 dti egr valve cleaning
cleaning egr valve on vectra 2.2dti
egr valve vectra c 2.2 dti
vauxhall 2.2 dti egr valve cleaning
vectra c egr valve clean 2.2 dti
vectra 2.2 dti egr valve
how to change egr valve on signum 2.2 dti
egr valve signum 2.2 dti
vectra c 2.2dti egr
egr opel vectra c 2.2dti
vauxhall signum 2.2 valve cleaning
cleaning egr valve on 2.2 vectra c
vauxhall signum 2.2 diesel egr valve
