Results 1 to 10 of 18
Thread: broken suspension
    Nottingham
    Default broken suspension
    so driving into the works car park this morning I must have flicked up a drain channel cover as i drove over it and it's full on belted the suspension:
    how easy to replace those 2 parts in the pic? looks like a cast part of the suspension and the large plate type part
    FURIOUS..
    Nottingham
    EDIT - where is my pic???
    Nottingham
    Nottingham
    the tracking is a mile out too.. and there is a leak over the suspension wishbone, it looks like oil.
    the item in the top of the pic is the subframe... it's bomb proof and won't be hurt..the triangular plate looks okay too from that image.. i'd not worry about that too much..
    if the steering feels funny, and there's a greenish oil on the wishbone it points to a steering rack fault.. the green is the PAS fluid and the cover may have caused the rack some damage..... it needs a proper inspection mate..
    Nottingham
    the subframe? ****e.
    it looks damaged. Has a hole in it.
    Nottingham
    maybe i can get it repaired in situ?
    from the photo all i can see is a scrape on the rear subframe mount....and the oily residue on the lower arm..there is a hole in the toeboard of the floor but it looks factory...
    the steering problem is far more important than any underbody damage.. you need to get the car inspected asap...it looks like fluid is escaping down the steering arm and through the rack gaiter..
    Nottingham
    yep. nightmare. gonna drop it off at the garage around the corner tomorrow. definitely a new, and a fairly bad, leak.
    the sub has taken a fair whack but my photo's aren't great. is the rack somewhere near the engine mount above that wheel? there is fluid there too
    the rack is above the centre back cross brace of the subframe, by the rear engine mount.. deffo sounds like the rack is damaged, or one of it's unions or pipes..
  1. Broken banks of river = broken vectra...
    By andrew e in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2012, 20:48
  2. Suspension knocking? Will Vec c suspension fit a Siggy?
    By shane5861 in forum Handling & Braking
    Last Post: 6th May 2011, 14:20
  3. Broken front suspension
    By Ratty Dad in forum Suspension, Wheels & Brakes
    Last Post: 30th March 2009, 23:47
  4. Broken Suspension Spring
    By 2.0 DTI SXI in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2007, 07:56
  5. symptoms of half broken suspension springs
    By ozzye in forum Suspension, Wheels & Brakes
    Last Post: 22nd May 2007, 22:59
