Results 1 to 10 of 14
Thread: Fault codes 0422 0432
    Regular Member jamesr's Avatar
    Lancashire
    Default Fault codes 0422 0432
    I keep getting the error codes :
    0422 and 0432
    Main catalyst below threshold Bank 1
    Main catalyst below threshold Bank 2
    Any ideas on a cure?
    yep, you need to change the cats in the manifolds....best bet is to get a set off of ebay...you need the manifolds off a 2.6V6 or 3.2V6 with the cats in between the two lambdas
    Lancashire
    Will this cause the car the run a bit "rough"?
    Especially at higer speeds and an acceleration cos it seems to have lost a bit of ooomph!
    Lancashire
    Think I need to book my car in at the GSi 3.2 garage
    Quote Originally Posted by jamesr View Post
    it won't cause rough running.. it just means the car is not running as 'clean' as it can...
    as there is no differential across the readings of the two lambda's per cat it can't meter the fuel ratio as correctly as it would wish, so may well be running of 'average baseline' values...
    lost oomph may well be the cat breaking up as well and blocking the downpipes, BUT if it is running off baseline values it will be down on power anyway ..
    don't buy the manifolds new.. they are over £500 each..
    Lancashire
    I have managed to get hold of the manifolds/cats.
    Is it worth changing the main cat too? and will this fit off the 2.6?
    I bet fitting is a B$tch?
    Once fitted how do I stop it running on"baseline values"?
    once it detects a correct range of figures from the 2nd stage lambdas it will revert to those....
    ignore the main cat, they are more or less superfluous on these cars as they are after the measuring systems...
    to change the manifolds, you just need to drop the front pipe down...disconnect the lambdas from the wiring looms, remove the rear heatsheilding from the back bank and be double jointed enough to get at all the manifold fixings..swap over your lambda sensors to the new cats and hope they are in good condition or it will all be to no gain....
    Lancashire
    So.....when are you free
    LOL... it's easy... you can do it at home...
    Lancashire
    So I could lose the main cat? put a straight thru pipe in?
  1. fault codes
    By Swedge in forum Electrical & ICE (including SatNav)
    Last Post: 17th November 2012, 17:30
  2. Fault codes???
    By lukesignum in forum Engine & Drivetrain
    Last Post: 11th January 2010, 20:15
  3. Fault code 0422 on 3.2 V6
    By Annalogg in forum Engine & Drivetrain
    Last Post: 12th December 2009, 10:48
  4. 2 fault codes
    By bigmac in forum Electrical & ICE (including SatNav)
    Last Post: 1st April 2009, 12:49
  5. Fault code 0422
    By jamesr in forum Engine & Drivetrain
    Last Post: 4th May 2008, 09:56
