Thread: Clutch again - Help please!
    Regular Member JKB89's Avatar
    Newport
    Unhappy Clutch again - Help please!
    It seemed to have died off for a while, but it's sprang back up again - for those of you who read my previous post its the same problem - for those that haven't here goes.
    A while back (just after the veccy was purchased) it started to make rattling noise whenever the clutch pedal was fully pressed down, or just before it reaches the bite on the way back up. However this subsided for a while, and there appeared to be nothing wrong with it...
    It's recently starting doing it again - had it plugged in to the reader, and the only fault was one with the heater plug relay (which we already knew about) so theres nothing detected there (as i'd assumed)
    The noise has recently got worse, and it sounds almost like a whirring/clunking when the clutch is pressed fully/near bite.
    Any help/ideas are very gratefully recieved - and if anyone has had this problem could they PM me.
    Could prices for possible solutions be included as well please.
    That's my cry for help over!
    -Joe
    Newport
    Bump.
    Anyone?
    london
    sounds like you have a dual mass flywheel problem its very common on these cars it clunks and rattles and gets worse in time till it fails you need to have the clutch and the flywheel replaced . be craeful there not cheap
    DeanF is selling a flywheel.. look in the for sale section.. be quick and bite his arm off for it....
    you'll save money
    Regular Member Finty's Avatar
    Jan 2006
    Ireland
    Its the dual mass flywheel all right. Had the exact same symptoms. You will need to replace the clutch and flywheel. Opel paid for labour since mine had only 50k klms on it. It was still €600 for parts alone.
    Newport
    Deans is sold lol, any idea where these can be purchased new then?
    Is it going to cost like ~£500? (just parts).
    Cheers.
    Jan 2006
    Ireland
    Quote Originally Posted by JKB89 View Post
    Cheers.
    If its the flywheel then yes plus the same again for labour!
    Newport
    Well im sure my dad would be able to do the labour part, if not - theres several people he knows that Im sure would be willing to do the job.
    any ideas where i can purchase?
    Ta.
    VX sell them, or any GOOD trade parts factor.....
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  3. 3.2 GSI Clutch
    By cmowen in forum Engine & Drivetrain
    Last Post: 23rd May 2010, 13:31
  4. Need help with clutch rattle that dissapears when clutch depressed
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 14th July 2009, 11:56
