Results 1 to 10 of 16
Thread: EGT sensor
    Regular Member Super T's Avatar
    May 2007
    On the Levels
    Default EGT sensor
    Is the egt sensor one of the lamda sensors ???
    code no p0546
    Help!!!!!
    nope... there's two sensors on top of your catalyst ( or stage 3 elbow) dependant on model year...one it the temp probe....
    if it's a later car i'm not sure they had them fitted...
    May 2007
    On the Levels
    It's an 04 Mark. Do you think it's an easy fix??
    Tyneside
    Temp probe is the one on the bottom of the cat IIRC.
    Quote Originally Posted by Super T View Post
    when you fitted your BSR downpipe did you have two 'senders' up by the turbo and one below the standard cat??
    Quote Originally Posted by mark1319 View Post
    thats the post cat lambda sensor.. it tells the car the final exhaust gas ratios..and gives back signals to determine the A/F ratio...
    May 2007
    On the Levels
    Do you think the volvo patch lead is at fault? The problem started when the downpipe was fitted.
    May 2007
    On the Levels
    Sorry Mark had to sit in the waiting room.
    Tyneside
    Ahhh right so it's the one on the top then???
    it 'could' be dodgy connections.. but it will need hooking up to TECH2 or Vauxcom to see what live readings it's giving back... or it could just be a damaged or dodgy sensor...
    May 2007
    On the Levels
    Thanks i'll try and thrash it out in the morning.
  1. Replies: 3
    Last Post: 13th August 2012, 22:25
  2. P0141-04 o2 sensor heater circuit open (bank 1 sensor 2)
    By Mark1892 in forum Engine & Drivetrain
    Last Post: 3rd August 2012, 09:19
  3. Fitting & Installation of ABS Harness & brake Help sensor sensor
    By Elahi_786 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2012, 20:46
