Thread: Bio derv
    Regular Member Dazfoz's Avatar
    Gloucester
    Default Bio derv
    Hi Guys,
    Does anybody have any info on the use of Bio Derv in my 1.9CDTI.
    Been and had a chat to the local supplier, who says that his product must be used as a 50:50 mix with standard derv (Due to the higher viscosity-any greater would lead to problems with vapourisation), but when being used in this way will give greater MPG, better performance and smoother & cleaner running.
    Now the sceptical side of me says that this is a load of bollox and it is just his usual sales pitch.
    p.s. I've tried the search function, but Bio is too short to search for!
    Daz
    member of the smoke patrol 230bhp+
    give vauxhall a ring 0845 090 2044 and they have all the info on bio as i think there is rules about what vauxhall have to do on if there cars run on bio
    if they dont have the info im shore somebody out there will now if it safe to do so
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Vx do not certify the use of any concentrations of bio diesel for 1.9 CDTi in Vectra.
    If VX won't certify the use, then don't use it. Simple really.
    Gloucester
    Quote Originally Posted by Ste View Post
    Thats all I needed to hear!
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    no problem, although of course you could be running up to 5% without even realising it. As standard pump diesel to BS:EN590 can have up to 5% Fatty Acid Methyl Ester content (ie bio sourced)
    Belfast
    Yep, specifically says in the manual no more than 5% bio in the CDTi.
    Though, the DTi is a different story - I ran mine for 2 years on 100% bio, no problems apart from making me hungry every time I got a whiff of my own fumes.
    Regular Member G.O'Rilla's Avatar
    Jul 2006
    On the road
    Quote Originally Posted by Dazfoz View Post
    You're right - complete cobblers. plenty of posts on this forum about using either old chip oil or bio diesel (two different things) so have a search. I'm not going into it all again - been there already.
    for my two penneth again.....
    for common rail vauxhalls the answer is no...end of....
    for DTi's it will be fine at 90% mix in the summer and 30% mix in the winter, but change the diesel filters soon after you start using it..
    Jul 2006
    On the road
    Thanks Mark - you obviously had a better day than I did. Still jetlagged as well so sense of humour failure......
    Going sailing the beast in the avatar saturday and sunday, but in a plane again next week
    better day??.. well it was only a 12 hour working day, so early finish day.....
  1. decat derv 150?
    By vectraross in forum Diesel Engine related
    Last Post: 10th September 2012, 19:04
  2. Thank you mr derv
    By big tee in forum Vectra C / Signum Car Chat
    Last Post: 20th August 2012, 23:32
  3. Which Derv lump is best?
    By coldo in forum Diesel Engine related
    Last Post: 28th February 2012, 23:40
  4. derv?
    By jimmyred in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2011, 10:43
  5. which derv is best and tuneable
    By ossypete in forum Diesel Engine related
    Last Post: 16th July 2005, 15:36
