Thread: Inside Roof Lights and NCDC 2013 Question...
    Northampton, UK
    Default Inside Roof Lights and NCDC 2013 Question...
    Hey there, one of the bulbs on the roof and blown, how do I -
    1 - Get in there?
    2 - What bulbs do I need?
    I had a look, but I cant see an "obvious" way to get in to it...
    Also, I've just bought a Pioneer Avic D3 Satnav with BT and Ipod connector, so will be getting the NCDC 2013 SatNav headunit removed, tech2'd etc...
    SO.... How much do you reckon its worth, JUST the Headunit/Cables/Ariel/2008 Maps CD etc? (but not the screen) I'm (probably) going to bung it on ebay once its been swapped over.
    Also, how do you use the trip computer etc, with just the steering wheel buttons with the aftermarket headunit? I normally have to use the buttons on the factory headunit etc to get to the fuel, distance etc...
    Thanks...
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    you should be abel to use the buttons on the end on wiper stalk.
    the front lights? remove the front blanking plate.. then you should be able to get the glass down.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    the clear plastic pops out (use a thin flat screwdriver) and the bulbs are a 501
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    you pull from the front of the clear plastic(by the sensors)
  1. ncdc 2013?
    By keith1983 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2012, 12:42
  2. ncdc 2013 speed signal question
    By jb1kenoby in forum Electrical & ICE (including SatNav)
    Last Post: 9th May 2010, 20:51
  3. Ncdc 2013
    By khile in forum Electrical & ICE (including SatNav)
    Last Post: 24th March 2010, 00:05
