Thread: help req steering wheel audio control switches
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Default help req steering wheel audio control switches
    I took the control switches off of the steering wheel in an attempt to do a mod i had in mind.
    Done the mod. now the switches dont work.
    Q1 anyone know what fuses control steering wheel control,s or do the switches have to be tech2 back in .
    any help greatfully received
    regards bob
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    i took mine out a little while ago and when replaced they didn't work.. found that the socket which they plug into if very flexable and was bending so they wern't making contact ... so after supporting the back with a bit of card they plugged in no problem and all works again.. just a thought HTH
    Engine : 2.0DTi
    Mileage : 73350
    Thanks steve i will have a look
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    you will have to show us the mod bob what have you done?
    Engine : 2.0DTi
    Mileage : 73350
    Just a little bit in material, as in the process of putting it all back together i knackerered one of the switches plug in connectors now but the mod consisted off carbon fibre covering of the control switches plus other bits and peices .Steering wheel looked really good for a short while
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    thats a shame Bob
    Engine : 2.0DTi
    Mileage : 73350
    Here you go ian an example of what i am doing
    Sunny Dartmoor
    That looks spot on there bob,great idea....
    20 Post(s)
    Vehicle : Vauxhall
    Engine : 1.9cdti
    Year : 07
    whow thats a neat mod Bob...............hope you sorted out the connections ok
    Engine : 2.0DTi
    Mileage : 73350
    Two new switches on order car is going in to dealers tommorrow to have another little mod done and they will be fitting new switches at same time . Have the template ,s cut allready for the tape to go on to new switches so first thing will be collect switches from dealer apply tape hand to them to fit job done.
  1. Steering Audio control stopped working -volume side
    By Vaux-Man-G in forum Electrical & ICE (including SatNav)
    Last Post: 8th February 2013, 16:18
  2. Halfcan & fullcan Steering Wheels & Audio control wiring
    By Woody in forum Electrical & ICE (including SatNav)
    Last Post: 21st January 2013, 11:54
  3. steering wheel audio control not working!!
    By swoop in forum Vectra C / Signum Car Chat
    Last Post: 11th August 2008, 17:24
