Thread: Can anyione help repair my gearbox on 3.2?
    Regular Member jamesr's Avatar
    Lancashire
    Default Can anyione help repair my gearbox on 3.2?
    My 3.2 Gsi has started whining in gear.
    Is there anyone on here can repair this for me?
    I have been quoted £680 to fix, but can't really afford that tbh.
    I am willing to travel
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    When you say, whine in gear, is it every gear? Does it change with vehicle speed, gear selection, acceleration, cruise and lift off coast down?
    Does it still happen in neutral and coasting along? When in gear and clutch depressed etc?
    Answering a few detailed questions could narrow down the search for the failed part (probably a bearing from what you're saying)
    How do you know it is defo the gearbox?
    Lancashire
    Quote Originally Posted by Ste View Post
    Answering a few detailed questions could narrow down the failed part (probably a bearing from what you're saying)
    I don't know for sure but fairly certain it is.
    Its does it in every gear, is more noticeable in the lower gears 1-2-3 and seems to get worse when you take you foot off the accelerator.
    Iam assuming its the bearings somewhere. don't think its the front diff? but not sure.
    Jul 2006
    Mexico
    Can´t help you there mate...but I hope you find a quick and "cheap" fix
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Is fluid level correct?
    Maida Vale
    I "think" the symptom of worn bearings is that when in neutral, the noise disappears or gets noticably quiter when you press the clutch.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    That would be geartrain bearing issues. When in neutral, a fairly rapid lifting off clutch pedal may procude a continuous noise.
    To offer good advice, we would probably need further info as to exactly when the whining happens and doesn't happen. Only then could it be narrowed down
    3.2's used to suffer with bad gearboxes that wore out bearings quickly. VX replaced them quietly.....
    if you can't find a box at a dismantlers, it will have to be recon'd....either way it's going to be several hundred quid...
  1. M32 gearbox can`t get gear selector back in gearbox HELP!
    By v33tra in forum Engine & Drivetrain
    Last Post: 30th March 2017, 07:43
  2. gearbox repair/replacement
    By jamesr in forum Engine & Drivetrain
    Last Post: 25th May 2008, 11:27
vectra 3.2 whining diff
vectra gsi 3.2 clutch whining
