Thread: Overfilled Oil on 2.8
    Oct 2007
    Bucks
    Default Overfilled Oil on 2.8
    Changed the Oil the other week. This evening checked the Oil level and noticed that the level was about 2-3 mm over the maximum mark.
    Should I drain a bit off to get this down to the Max mark? How significant is that 2-3 mm?
    member of the smoke patrol 230bhp+
    id say that youd be ok but im shore mark will be about to confirm if its ok
    Ashington, Northumberland
    You'll be fine with that. It isn't seriously overfilled.
    Oct 2007
    Bucks
    Cheers guys, wasn't sure but you've put my mind at rest.
    Regular Member LarfinBoy's Avatar
    Bedfordshire
    Default oils well that ends well
    How much over is a serious overfill 5mm over the max?
    My oil is black and was told this was "normal" - is that coz they suck it out these days rather than drain it?
    The oil was changed at service 10k ago, but not sure if I want to leave it until the next service c20k.
    Was thinking of getting for an oil flush n change - is it worth it ??.
    3.0CDTi Elite
    East Midlands
    Quote Originally Posted by LarfinBoy View Post
    3.0CDTi Elite
    On a diesel engine the oil will turn black after about 100 miles.normal..regarding overfill of oil...it takes a ltr of oil from the min mark to take it up to max..5mm over this make imo will make no difference.
    personally, i'd never leave the oil in for 30K...it's far too long.. i 'know' it's wjhat VX printed in the book, but thats for cars that sit on the motorway all day every day..
    look at your annual mileage, and aim to change it very 6 months if you do a lot of short trips, or at least annually if you do longer runs...
    Personally, on my own cars, i like it changed every 6-8,000 miles...
    and as for overfilling...as Gary said. a couple of mm is okay.. 5 is starting to get a little bit high...thats nearly 1/4 of a litre overfilled..
  1. Help! Oil Overfilled by Kwik Fit, Advice needed!
    By veccy101 in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2012, 17:00
  2. Replies: 7
    Last Post: 29th June 2011, 12:02
  3. Overfilled the engine with oil
    By whelp in forum Engine & Drivetrain
    Last Post: 30th April 2011, 21:46
  4. Overfilled with oil
    By tjsignum in forum Engine & Drivetrain
    Last Post: 9th March 2009, 22:06
