Results 1 to 10 of 22
Thread: 1.9 cdti missfire
    sheffield
    Default 1.9 cdti missfire
    hi guys, new on here, just bought a 04 vectra 1.9cdti 8V . wonder if anybody can help.. get a missfire or jerking on light throttle above 2000 rpm , if i floor throttle & accell hard theres no missfire at all car pulls really well , its ok when car is cold just dose it when hot, cars done 93k miles , replaced water temp sender today (gauge not working ) replaced air filter .
    cheers guys any help would be much app...
    Bristol
    Vehicle : CDTI 150
    There is an issue with the injector wiring on CDTIs, Vx do modified looms with thicker wire. Strangely it affects the No 3 injector. Could be worth a try.
    sheffield
    Thanks for the reply m8 , would this be a full engine loom or just the injector loom , do you no if this is a recognised fault , known to Vauxhall , sorry to sound a bit thick m8 , cause all this is new to me , ive owned passats for the last 5 yrs .
    Bristol
    Vehicle : CDTI 150
    Sorry should have been more specific, This is a known fault and Vx supply a modified injector loom (1 for each inj), not very expensive.
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Had the same issue with my CDTi 150, VX changed the Injector Wiring looms, all sorted
    Belfast
    I have it with Tesco diesel the odd time. Misfiring, lumpy idle. BP diesel it's fine.
    Regular Member VXR CDTi's Avatar
    Jan 2008
    South Wales
    Just found this after typing 'Vectra Injector Wiring Loom' into google search bar:
    http://www.migweb.co.uk/forums/engin...i-150-sri.html
    Jan 2008
    South Wales
    Just cleaned the injector wiring loom plugs as they probably aint been touched since they were put on the car in the factory, took her for a spin just now and 'VOILA' the problem has gone, Woohoo iv got a huge smile on my face!!!!!!
    Plug 3 was black so I blew all the sh*t out then cleaned the pins by pushing them on and off, did same for all four and jobs a goodun!!
    Sheffield
    You did'nt take any photos by any chance did you as it sounds like I might have the same issue, but I'm pretty crap under the bonet and not sure what to look for to clean?
    Jan 2008
    South Wales
    Quote Originally Posted by biggiepop View Post
    Pop the bonnet and take off the engine cover 1st!
    Your engine may be layed out a little different to mine coz urs is the 1.9 CDTi 120 and I have the 150 so im not 100% its the same, but basically ur looking for the injectors with the injector loom plugs on top as circled in the 1st pic. Simply unclip the yellow catch and press on the release button and just pull off, it shouldnt be 2 difficult. Then all you need do is give each one a blow and push on and of 2/3 times just 2 clean any crap thats caked on the pins in the plugs. If u have any carb cleaner available give them a blast but wait for them to dry/evaporate before putting them back on and starting up the engine. Make sure u do one at a time and reclip the yellow slider before doing the next plug, u dont want to mix them up now do u!!!
    What you got to remeber is that these plugs may not have been cleaned since the car left the factory, and with hot/cold weather the pins can sometimes corrode! So annual checks of these should keep them working nicely!
  1. Serious missfire 3.0 V6 CDTI
    By SRI-150 in forum Engine & Drivetrain
    Last Post: 14th August 2011, 07:45
  2. Missfire!
    By R1-RAB in forum Engine & Drivetrain
    Last Post: 6th February 2010, 21:05
  3. missfire
    By alexgrfc in forum Engine & Drivetrain
    Last Post: 28th October 2009, 00:43
  4. 150 cdti 1000 rpm missfire
    By sshooie in forum Diesel Engine related
    Last Post: 4th July 2009, 11:08
  5. CDTi 150 Missfire
    By sdemps in forum Engine & Drivetrain
    Last Post: 17th June 2009, 00:17
