Thread: Mystery fluid container!!!!
    Regular Member blues n twos's Avatar
    Seer Green, Bucks
    Default Mystery fluid container!!!!
    Ok.... at the risk of being a dumb a**....
    Whats the resivoir in front of the drivers front wheel tucked down under the headlight.
    This is the drivers side not passenger side. No way to access it unless the bumper comes off and it has a wide black screw top and max/min on the side??????
    Just wondering because mine could do with topping up and I don't know what to top it up with
    Jon
    Regular Member wardy's Avatar
    Chichester
    Think its power steering. Sure someone said its a bumper off job to top it up.
    Oct 2006
    Waterloo, Liverpool
    12 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Quote Originally Posted by wardy View Post
    Correct. The power steering fluid reservoir is either under the right front bumper or at the rear of the engine depending on which engine you have.
    [Ex]Admin Duncan's Avatar
    Yep, as said it's power steering fluid. It is possible to top it up, if needed, by removing the airbox and using a long stemmed funnel (the ones with the flexy stem). It shouldn't need topped up normally - if it does then you've got a leak somewhere.
    Seer Green, Bucks
    That might explain what the clearish fluid is that I have seen on the engine
    Thought it might be gearbox related as there was a small amount dripping of the bottom. Would rather it be a power steering hose / seal or something.
    I will top it up and clean up to try and find where its coming from. What a daft place to put a resivoir Loads of room at the back of the engine!!!
    Thanks for clearing that up
    Jon
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    you will need the green fluid as its called central hydralic fluid chf for short
    Seer Green, Bucks
    I replaced some in my Vec B but that was standard power steering fluid I think.
    Is it different in the Vec C ?
    Jon
    Quote Originally Posted by blues n twos View Post
    Jon
    yes mate completely different
    Seer Green, Bucks
    Typical.... means I have to go buy some now
    Is this the same stuff Citroens use then ?
    Jon
    Jon
    no m8 , it cost about £10 from the dealers
  1. Air-con mystery
    By chewy71 in forum Vectra C / Signum Car Chat
    Last Post: 23rd August 2011, 16:32
  2. A bit of a mystery
    By watchman in forum Vectra C / Signum Car Chat
    Last Post: 3rd June 2011, 06:44
  3. Key Fob Mystery
    By macdad in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2010, 22:45
  4. mystery pic......
    By david.aka.judas in forum General Chat
    Last Post: 18th July 2010, 22:07
  5. Make Sure The Container Goes The Right Way Round
    By Ben H in forum Comedy & Humour
    Last Post: 31st January 2007, 23:29
