Thread: warning ligts on, on dash
    Regular Member Gr4eme's Avatar
    Feb 2007
    Durham
    Default warning ligts on, on dash
    Came back from holiday on sat, car had been left in airport carpark for a week. Started it up, pulled away and noticed i had the spanner light on. I pulled up and switched off engine, restarted but the light stayed on for the journey home (bout 20 miles). Called into asda jumped back in car restarted and the light has gone out.
    This morning swmbo took the car to work light still out, but then tonight on the way back home the exhaust gases light came on. I took the car out for spin the light was on and car was ticking over very lumpy. Took it out a little later now the light is out and is running much better.
    i've got it booked in to be looked at on thursday but if there is no light on will it have a code stored.
    Ta.
    11 Post(s)
    Providing the car/spanner light remains lit until the engine is started then yes; as this indicates there is/are stored fault code(s).
    Gloucestershire
    Quote Originally Posted by Gr4eme View Post
    Ta.
    If you go to a specialist with some decent kit they can take a look at the Freeze Frame data - this is stored with details of the conditions when the MIL light last lit. They are kept in memory for some time, or until the light comes on again
    Gareth
    Feb 2007
    Durham
    had no lights on at all today and car is running ok now. so will there still be a code stored or should i cancel the visit to the stealers until the lights re-appear (if they do) ?
    codes will still be stored...if you are curious you could go and find out what they are...But personally, if you don't have access to diagnostic kit i'd leave it till it reoccurs..
    Feb 2007
    Durham
    So i had the codes read today and even though its running perfect now the verdict is, it needs a new egr valve and a swirl valve accentuator rod thingy, no surprise there then.
    They ordered up the parts and gonna give me a ring when the arrive....
    hmm.. another victim of the CDTi's hunger for engine parts.....
  1. warning light on dash
    By tj56 in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2011, 14:50
  2. dash warning light
    By graememk in forum Engine & Drivetrain
    Last Post: 1st November 2010, 02:26
  3. dash warning light
    By taffy bhoy in forum Electrical & ICE (including SatNav)
    Last Post: 4th April 2010, 17:49
  4. Oil warning on dash
    By thevec150 in forum Engine & Drivetrain
    Last Post: 18th February 2010, 12:36
  5. Warning On Dash
    By Diesel279 in forum Vectra C / Signum Troubleshooting
    Last Post: 14th January 2009, 20:16
