Thread: more pedal travel after upgrade to 314mm
    Regular Member fuzzbomUK's Avatar
    Milton Keynes
    Default more pedal travel after upgrade to 314mm
    Hi all,
    This weekend I upgraded my 302mm to the 314mm on my GSI.
    But now the brake pedal does go further down than it used to, Is this correct?
    They do work really well. Just have something nagging in the back of my mind.
    All stuff fitted and bled correctly before you ask, I even bled the system 3 times and got a mate (qualified VW mechanic) to check it all over.
    The only theory we could come up with was that the pistons in the callipers being bigger it takes more fluid to apply them.
    Is that such a silly theory?
    The other theory of course that its all in my mind.
    Belfast
    I had the same when I put the VXR 322mm jobs on my Astra. Took a few weeks and then a good beasting for the pads to bed in, at which point the pedal returned to normal.
    First few days the pedal was nearly hitting the floor, now they're solid as a rock.
    Milton Keynes
    Phew.
    Makes me feel loads better. was worried as i heard horror stories of having to use a tech2 and bleeding the ABS etc.
    as i say thing that confused me was they stop really well..
    [Ex]Admin Duncan's Avatar
    When I upgraded my 302mm fronts to 314mm I never had any issue like that - nice and solid from fitment and tightened up a bit more as the pads bedded in.
    When you say he pedal goes down further than before, how much are you talking about?
    Full Member Jay Kay 313's Avatar
    Burgess Hill
    Yes this is normal mine did the same it just took a little time to bed in I drove from Brighton to Poole that did the trick It will get better
    Astra Estate SRi XP 1.7 CDTi 100
    Thats because I was involved in their fitting.....and you and spikey got the benefit of the GSi man's expertise..
    Exactamundo!
    Milton Keynes
    The pedal only goes around an inch or so more, but it is noticeable.
    want to make sure there ok because i want to do a remap next )
    I wouldn't worry about an inch more travel - it may well firm up as the pads bed in.
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
  1. Vec gsi 314mm ( bonking sound when tapping the brake pedal ) HELP!!!
    By big rich in forum Suspension, Wheels & Brakes
    Last Post: 23rd December 2012, 02:35
  2. upgrade the 314mm to vxr set up or upgrade the rears?????
    By rob warrington in forum Handling & Braking
    Last Post: 24th September 2012, 09:26
  3. clutch and pedal travel
    By reeseandellie in forum Engine & Drivetrain
    Last Post: 4th May 2012, 07:52
  4. Accelerator pedal travel problem
    By AFA82 in forum Engine & Drivetrain
    Last Post: 24th February 2012, 20:42
  5. brake pedal travel
    By djlee in forum Suspension, Wheels & Brakes
    Last Post: 13th August 2011, 00:14
