Thread: 1.9cdti - high idle speed and new "noise"
    Jan 2008
    Gloucestershire
    confused 1.9cdti - high idle speed and new "noise"
    First post - so hope someone knows what I should be looking for !
    04 1.9 cdti - engine new (under warranty - oil pressure problem) about 15k miles ago.
    Just started this weekend - idle speed has now moved up to 1100 - used to be a steady 750 ish, and there is a new "whurring" noise which is engine speed related.
    Oh - and I had to put about 250ml of water in her recently to top her up, warning light came on when I was parked on a steep incline - which is why I checked but it was hardly a huge amount and it was not on the minimum level.
    Seems to drive ok - no warning lights/lack of power etc ...Doesn't run on when turned off, starts fine - or is it me and it is taking a few more turns now before she fires in the morning - but it is colder than of late...
    Baffled.
    But I know it's not right..
    Jan 2008
    Gloucestershire
    Eek it died...
    So, normal start this morning, engine light within 5 yards of moving off, restart - extinguished -
    Idle 1100
    after 1/2 mile - cigarette lighter socket powered gps - goes off and on.
    after another half mile - abs/traction control lights on
    3 seconds later - loss of power steering
    2 seconds later - power steering warning light.
    park.
    turn off
    turn on - all the lights - but no start - all the lights go off and a clunking from a solenoid I had not heard since I drove 1960 mini's when I turn the key...
    Call recovery.
    Arrived - car started - but still got it recovered to dealer.
    I think the problem is this - but only my thoughts - others welcome !
    Alternator/charging circuit/battery is not behaving - when it did start it definitely did sound as energetic when turning over as normal.
    This may explain the interesting behaviors of the gps/abs lights /a and the power steering (which I believe has an electric/electronic conponent(
    So - that added to this new "noise" / "whine" I heard over the weekend (strangely not there after it all fell in a heap this morning - finally broke ?) - which could be an alternator/charging circuit issue - then we could be on the track of the solution..
    Also - this air con valve under the glove box - seems to happily click at regular intervals even when the car is turned off and locked... So is that having a drain on the battery enough that it drops below a trigger voltage, the cars electronic wizardry gets upset - but the power in the battery is still enough to heat the glow plugs, turn on the fuel pump and turn her over.....
    See what I'm thinking ? The top tech chap at the dealer concurred with me anyway - so let's see what they find.
    I've got the advert ready for my wife's car so I can sell it to pay for the repair....
    Anyone else got an idea ?
    Belfast
    50p says the alternator ate itself.
    Jan 2008
    Gloucestershire
    Default prize to that man
    Alternator - 10 V output...... Could have done that myself....Luckily with the full explanation I gave them they had it identified in a few minutes - so not too much of a bill for labour...
    Still - it's only £531 inc vat to supply and fit......
  1. High idle speed
    By 19CDTi in forum Engine & Drivetrain
    Last Post: 1st July 2012, 11:02
  2. A "Man's Man" - My Idle Thoughts
    By Rebellion in forum The 'Off Topic' room
    Last Post: 23rd May 2012, 11:15
  3. battery charging rates at idle and high speed
    By justin32 in forum Engine & Drivetrain
    Last Post: 21st November 2011, 01:29
  4. Signum 2.8V6T idle speed high
    By BYGino in forum Engine & Drivetrain
    Last Post: 30th June 2011, 20:59
  5. Very high idle speed (3500rpm)
    By CodeV in forum Engine & Drivetrain
    Last Post: 19th February 2010, 01:08
1.9cdti idle high
