Results 1 to 10 of 20
Thread: cd starts from beginning
    N.Wales
    Default cd starts from beginning
    Guys,
    Please please please tell me that there is a way to stop the CD70 from starting the loaded CD right from the beginning every time you switch off!?!
    for example, i've listened all the way through a cd and got to track 15, i go to fill up with petrol, turn off, turn back on and it doesn't remember where i was, so it starts from track 1 again, and i have to forward to track 15...
    Ely, Cambridgeshire
    58 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    That sounds like it's not got a permanent live correctly fitted to it.
    If you add a preset channel on the radio, does it lose that as well when you turn it off? If it does, then that's the problem.
    [Ex]Admin Duncan's Avatar
    Sounds like it's losing it's power when you turn the unit off.
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Are you talking about a CD or an MP3-disc ?
    Here, there and every where!
    It's always done it since i had it and i thought it was how the CD70 worked
    It might be a power issue but as the Parrot kit works the correct way and turns off with the ignition i didn't give it a second thought TBH
    Chester
    I tried every configuration I could think of coming home tonight to try and get mine to do the same but it always started from where it left off.
    I'll have a look at the weekend. It might need the Parrot kit putting on it's own feed and let the SOT lead just sort out the radio power.
    I can only think it could be that but i'm sure it did it before the kit was installed.
    N.Wales
    Quote Originally Posted by Ian-Highlander View Post
    stores all other settings... just not CD memory it seems.
    Quote Originally Posted by sig63 View Post
    Normal audio CD
    Quote Originally Posted by Caterman View Post
    See you this weekend then
    IIRC the MP3's start from where they leave off
    Have you tried that Baz?
    N.Wales
    nope, not tried MP3 yet... will have to get some blank cd's first
  1. The beginning for the cdti 150
    By Baldwin in forum Vectra C / Signum Car Chat
    Last Post: 14th October 2012, 21:34
  2. the beginning
    By RaulSilva in forum Introduce yourself.
    Last Post: 6th August 2012, 22:51
  3. In the beginning...
    By Penfold101 in forum Comedy & Humour
    Last Post: 17th June 2011, 17:28
  4. Morning starts are ok - Afternoon starts are a ******!
    By Madaxeman in forum Troubleshooting
    Last Post: 28th February 2011, 19:38
  5. It's Only Just Beginning...
    By Mark The Cabby in forum Insignia Chat (READ ONLY)
    Last Post: 2nd April 2009, 10:58
