Thread: Strange sucking noise CDTI 120
    Regular Member GoldenWonder's Avatar
    Durham
    Default Strange sucking noise CDTI 120
    I know noises are a bit tricky to diagnose from descriptions but here goes..
    On my CDTI 120, when the engine is cold (or not fully hot anyway) I get a strange sucking sort of 'gasp' noise when changing up through the gears (unless I let the revs drop down low). It only last a second (it coincides with the clutch being depressed) and is noticeable from 1st to 2nd, 2nd to 3rd and less so 3rd to 4th (presumably because the difference in engine speeds are less)
    When the engines warm, it seems to go away. Anything to worry about?
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    Turbo ?????????
    Durham
    Not a normal turbo noise then?
    I did notice in the service history that the turbo was replaced at 54k, and its now at 70k
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    It's sooo difficult to diagnose these sorts of noises when you can't hear them.
    Could it be one of the rubber pipes from turbo to intercooler and vice versa has a split in it??
    Just a suggestion.
    it would be unlucky to have 2 turbos go on a vehicle.
    Diesel Turbos are quite robust although failures aren't exactly unheard of in the CDti.
    Durham
    I did think of a split pipe maybe (its mentioned on here before) but why only when the engine is cold?
    The turbo is fairly noisy anyway, in that zzzzzz kind of way but only makes this noise when cold.
    nottingham
    try driving along in 2nd build up revs quickly and let go of the accelerator and see if it does it then, if it does this is perfectly normal as its just the waste gate. I have same engine and mine does this kinda sounds like a mini dump valve.
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    same here, only mine is exagerated by my twin exit exhaust.....sound's great imo
    Midlands Mod Shop - NFFC.
    Durham
    I'll give that a try - just need to find a quiet stretch of road!
  1. Strange Noise on Start Up From Cold 1.9 CDTi 150
    By smallwheels38 in forum Engine & Drivetrain
    Last Post: 11th June 2016, 15:33
  2. 1.9 cdti engine strange noise
    By n1ks0n in forum Engine & Drivetrain
    Last Post: 10th January 2013, 00:49
  3. Strange noise from my Vectra CDTI
    By Jabbekot in forum Engine & Drivetrain
    Last Post: 3rd December 2012, 23:06
  4. Loud sucking noise
    By D33ler in forum Engine & Drivetrain
    Last Post: 25th March 2012, 12:51
  5. strange noise from engine cdti 150
    By kamar in forum Engine & Drivetrain
    Last Post: 12th April 2010, 17:16
