Results 1 to 10 of 21
Thread: Diesel into a Petrol V6
    Regular Member KieronGSI's Avatar
    Apr 2008
    Aylesbury
    Default Diesel into a Petrol V6
    Well i have been a muppet today it appears i put £20 of Diesel in my car on an empty tank and didnt realise until it coughed and spluttered so i pulled over, and now it wouldnt start obviously. Does anyone know what sort of damage i have done? Any help would be appreciated.
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI158
    Year : 2012
    Need to get it drained out (fair amount went it there). A for the damage, I doubt anyone could say for sure unless they saw it. I'd call out a reputable mechanic.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Piston top land broken (intake side) - Bad engine running especially after cold start and cold drive ability - Knocking noise (sometimes failure code P030X is set) - Molten catalytic converter as a consequential damage - Increased oil level (oil dilution)
    Also check the filler neck mate at the nozzle on diesel is wider so could damage your petrol neck.
    Apr 2008
    Aylesbury
    Does anyone know of a way to drain the petrol tank on a 3.2 v6?
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    hose pipe in and suck it out?
    Mileage : 000
    Quote Originally Posted by Danwells72 View Post
    I thought they had an "anti syphon" neck, so you will not be able to suck it out ( to stop it from being stolen). You might have to drop the tank to empty it?..
    May 2006
    scotland
    Awh I feel for u mate. I did the same in 1980 with a TR7. Easily done. Luckily I hadnt started the engine. Had 2 join the RAC on the spot, they towed it away an cleansed the tank. Good luck, hope not 2 much damage.
    Oct 2006
    Waterloo, Liverpool
    12 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Thought you couldn't get a diesel nozzle into a petrol car unless you forced it in?
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    It is very easily done, I put £8 of unleaded into the other-halfs 1.9cdti before realising....Lucky for me I filled it up with diesel to thin it out...possibly cleaned some gum off the cylinder walls, but it has been fine for the last 15,000 miles since it happened...
    although on recollection, I think we had a few jittery problems when pulling away at first...'til the unleaded had all been diluted or flushed away by the diesel...
    Mileage : 000
    Quote Originally Posted by john_k_sri View Post
    Gve it a try John and let us know. But yes I thought the Diesel nozel was larger?.
  1. petrol or diesel
    By kram1000 in forum Vectra C / Signum Car Chat
    Last Post: 13th August 2011, 15:10
  2. Petrol in Diesel!
    By P-Mutton2.2 in forum Vectra C / Signum Car Chat
    Last Post: 24th October 2009, 06:53
  3. PETROL vs DIESEL?
    By vectrahuw in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2008, 00:07
  4. Diesel and Petrol
    By GazVXLINE170 in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2008, 22:29
  5. Petrol vs Diesel
    By kryton01 in forum Diesel Engine related
    Last Post: 14th September 2006, 06:49
