Thread: Dilema.. help required
    portsmouth
    Default Dilema.. help required
    Had some 18" vauxhall alloys delivered the other day along with some new rubber to go on them. went today and had the tyres fitted to the wheels but as the guy went to fit the wheels they fitted snug to the hub but then also against the huge calipers of the signum. so im in need of some spacers and extended bolts im guessing. Anyone know where i can get them??
    i thought vauxhall alloys would have been alright but obviously i was wrong..
    it all depends on the offset of the wheel....
    if you do fit spacers, make sure you get bolts extended by the same amount...
    roadhouse wheels sell them via their website
    portsmouth
    yeh.. had a guess it could be the case.
    the offset of the alloys is 45ET, Does anyone know what they should be for the 3.0CDti signum ?
    ET38-ET41 sticks in my mind, but i could well be wrong..
    portsmouth
    ive still not fitted my new wheels, ive been busy with work.
    Im Just trying to work out what i need to get will a 5mm spacer on each hub work, cause if im right in thinking that will take them to an offset of 40ET is that right or will it be a adding to it and make them a 50ET. as you can tell im notto good with this. lol
    any help will be greatly appreciated.
    Regular Member hagga's Avatar
    kingswinford
    with a 5mm spacer they'll be et40. my wheels are et45 and I've fitted 10mm to the fronts to clear the calipers. just make sure the wheel centres up ok on whats left of the spigot, I had to have some custom ones machined up that fitted the wheel without the plastic spigot ring. www.wheels.uk.com can get hold of what spacers and bolts you need but you may have probs with longer locking bolts. one way around this is to use a threaded stud and a locking nut.
  1. Serious Dilema!
    By BigWilko in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2012, 16:13
  2. Dilema....What to do?
    By gibbon7000 in forum General Motoring Chat
    Last Post: 20th November 2011, 19:42
  3. Bit of a Dilema!!
    By Avenged in forum General Chat
    Last Post: 16th March 2009, 21:58
  4. Dilema.....
    By adamtaylor in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2008, 07:54
  5. New Car Dilema
    By OilBurner in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2007, 22:04
