Thread: Flywheel Question
    bolton
    Default Flywheel Question
    HOW WOULD I KNOW IF THE FLYWHEEL NEEDS REPLACING? I KNOW THE CLUTCH NEEDS REPLACING, AS THE CAR DOESN'T PICK UP AS BEFORE AND THE PEDAL TRAVEL IS AT THE TOP. PLEASE HELP
    Here, there and every where!
    Moved to the correct section!
    ........and there's no need to SHOUT!
    [Ex]Admin Duncan's Avatar
    You'd get quite a nasty banging noise from the gearbox/clutch area if the flywheel was going.
    Mileage : 000
    Mind you they will soon tell you when you have a new clutch fitted.
    bolton
    FLYWHEEL QUESTION AGEN
    how loud would this be? as my engine sounds bit louder than before or it may need a service as its due.
    how much does flywheel cost?
    Flywheel is around £400 just for the part. As for noise, quite a noticeable banging noise is what I've heard it described as. Maybe somebody who's actually had a flywheel issue will be able to elaborate.
    Regular Member andymagee1982's Avatar
    May 2008
    Widnes.
    Half dipped,
    Thats when you will get the loud rattle. Not a nice sound!
    Never got mine done. so price i have no ida!
    Regular Member willoftoon's Avatar
    FOREST HALL NEWCASTLE ,,,,,OR DECKHAM ,, ON SUNDAYS .. DINNER TIME MAMMY,S
    i got quoted 1500 by vaux for dmf and clutch fitted but can get it cheaper by a m8 who works for vaux ..i also know where there is a 2nd dmf if u want it don tknow price but cant get 1 for u its off a 1,9cdti 150
  1. 2.0 DTi flywheel question
    By Hammy in forum Engine & Drivetrain
    Last Post: 13th April 2010, 10:47
  2. 3.2 flywheel question
    By lee866 in forum Engine & Drivetrain
    Last Post: 24th October 2009, 16:09
  3. Flywheel Question
    By sdemps in forum Engine & Drivetrain
    Last Post: 26th January 2009, 23:44
  4. 07 Siggy Flywheel question
    By Pepsi Max in forum Vectra C / Signum Car Chat
    Last Post: 13th January 2009, 00:20
  5. Flywheel Question
    By AntB in forum Engine & Drivetrain
    Last Post: 24th April 2008, 00:15
