Results 1 to 3 of 3
Thread: The Handbook says........
    Regular Member bennettboy's Avatar
    Havant UK
    confused The Handbook says........
    Hi, i have a 54 plate 1.9 cdti 120 and when i switch the ignition on the car with a spanner through it illuminates and goes out the minute i start the car, so i have had a look in the good old manual and it says " Have the fuel filter checked for water residue". I have mentioned this to a couple of people and one said doubt it very much usually means an EGR problem get the car fault code read to which i have and nowt,zilch,nadda no codes stored what so ever and the light has never appeared when driving nor has the EML could the handbook be right and if so would draining the filter housing rectify the issue.
    bennettboy
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    means it has an old fault code stored.... should reset the light after 40 ish restarts with no detection of the fault or you can diconnect the battery for 30 mins to clear it... on the other hand mine did this an i changed the glow plugs with the weather being cold and no light either way unless it stays on i wouldn't worry too much HTH
    Jul 2006
    Mexico
  1. Aux Input (Latest handbook)
    By leeds vectra in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2011, 02:47
  2. owners handbook ?
    By mickey, c in forum Vectra C / Signum Car Chat
    Last Post: 4th October 2010, 00:18
  3. owners handbook
    By rob warrington in forum Vectra C / Signum Car Chat
    Last Post: 29th May 2010, 23:32
  4. Does anyone has owners handbook
    By violetinis in forum Vectra C / Signum Car Chat
    Last Post: 8th October 2007, 10:58
