Thread: Trip computer screwy
    Regular Member guitarbaz's Avatar
    Jan 2008
    A Geordie in Lincoln
    Default Trip computer screwy
    Now I'm not too sure if this has occurred since the BSR remap but...
    The consumption (instantaneous) has a habit of dropping about 20mpg for no apprent reason. I'm happily tootling along on the motorway at 70 with cruise control on and it'll be reading around the 50mpg mark on average, then it'll suddenly plummet to about 30 for no reason that i can suss out. i don't think it's an engine fault as it sometimes resets itself if i turn the ignition off and then back on again. although this "fix" is working less and less.
    it's a minor niggle i know but i do a lot of miles and like to keep close tabs on consumption.
    this sound familiar to anyone??
    cheers
    Does your car have a DPF installed? If it's an estate or an auto then it will given the year.
    EDIT: Just saw that you do have an estate, so it'll be the DPF kicking in on a longer drive.
    Jan 2008
    ah right. well it does do it on longer drives occasionally but sometimes when i've just set off too. it'd be interesting to know the cycle times or if the filter senses when it needs cleaning. either way it seems to do it very regularly so maybe something is amiss there?
    cheers for the info, i've learned something today!
    Jan 2008
    just done a search on the site and there's a shed load of info in this. seems i'm not the first to be worried at sudden increase in consumption and also that noticeable smell of burning rubber!!
    There was something about the DPF cycle being reprogrammed on cars. What I can't recall is from what year the reprogrammed version was standard, and whether it made the cycle more often or less often. One of the 1.9 guys may be able to shed more light.
    EDIT: Yep, a search should bring up the info I mentioned as it's been covered in a fair bit of detail on here.
  1. trip computer..
    By djdee in forum Vectra C / Signum Car Chat
    Last Post: 18th March 2011, 12:53
  2. Trip Computer
    By Matt Cutler in forum Vectra C / Signum Car Chat
    Last Post: 23rd June 2009, 22:27
  3. anyone added trip computer/board computer?
    By Craig1985 in forum Vectra C / Signum Troubleshooting
    Last Post: 24th August 2008, 02:33
  4. trip computer
    By vectramad in forum Vectra C / Signum Car Chat
    Last Post: 22nd August 2008, 19:22
  5. Trip Computer even possible?
    By delete2 in forum Electrical & ICE (including SatNav)
    Last Post: 1st August 2008, 01:00
