Thread: Explanation of problem needed - what is wrong???
    Regular Member yan_d3's Avatar
    nr Emouth, devon
    Question Explanation of problem needed - what is wrong???
    As I'm not very good with engine problems finding so I'm coming to you guys with Q what might be wrong and how can I fix it. My main problem is appearing when I'm accelerating and getting up to sth 2500rpms' then spanner light on my dashboard is coming and engine is going into "slow-motion mode" - I'm calling it like that because I cannot exceed 2500rpms' on each gear and have no proper acceleration because of it. Still can drive (up to 80mph on the 5th gear) but it seems to struggle when it gets to 2500rpms' and not going any further. It happens to me on motorway couple of times and now it's happening every time now within 10 mins after starting the car. What is most interesting when I pull over somewhere on the side of the road turn the engine off and start it again after a half or one minute problem seems to disappeare and everything works quite normal. Somebody told me to reset ECU but don't know will it work.
    If anybody of you knows that problem and know how to efectively fix it please let me know - I cannot wait till my veccy will die
    I'm not scared with doing jobs on my car because I love all the DIY jobs and if there is sth I can do on the car I will but finding whats wrong this time was bit hard and do not want to rely on guesses.
    Many thanks for every advice
    2002 VECTRA LS 2.0CDI
    Aberdeen
    Sounds like 'Limp Home Mode'. If you can get the fault codes read that may help to identify the issue.
    I'm sure somebody will be along soon with more info.
    the most popular 'faults' on DTi's that makes them go into 'limp home mode' are:.
    1: boost pressure sensor.. it gets caked in an oily filthy hard sludge..a clean with carb cleaner normally restores it back to good health
    2: the EGR valve getting coked up with the same hard sludge, again, a good clean with carb cleaner helps it out no end..
    of the two, i think it may well be the boost pressure sensor..
    nr Emouth, devon
    I found EGR valve and boost pressure sensor, took it apart clean it and still the same. I cleaned even manifold intake from the hard sludge - was really filthy. I can hear the slight difference in soud but again when I get up to 3000rpm it getting into LHM with the spanner light on the dashboard and limiting engine work to 2500rpm on each gear. Acceleration is low - sorry I said acceleration [laught] - 0-62 about 25 sec - thats tragic ((
    I started wondering is turbo gone in it or if not have got no clue. Please help ((((
    Regular Member neilshaw1980's Avatar
    Oct 2006
    coventry
    Check the turbo boost hoses for splits. Does it smoke excessively?? Can you hear any sort of whooshing noise like a hairdryer??
    Regular Member Andy17899's Avatar
    Jun 2007
    West Midlands
    Vehicle : Vauxhall Vectra SRI XPII
    Mileage : 68K
    If you find out what it is mate let me know, mine does exactly the same thing, but only at 70+ on the motorway, after 20 miles or so.
    I wish i knew!
    nr Emouth, devon
    Quote Originally Posted by neilshaw1980 View Post
    Yes it smokes excessively while in 'limp home mode' with the spanner light on the dashboard and mpgs' are increasing. I'll investigate any further steps being adviced. Can't hear any whooshing noises - engine seems to be bit louder than before but thats it.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    i might be the maf but might be worth getting it code read, which will tell you whats wrong
    Cirencester
    Im going for the split boost hose!
    Oct 2006
    coventry
    Quote Originally Posted by JonR View Post
    Thats what i'm putting my money on. Check both hoses boost hoses and make sure to check all the way around them because they often split underneath where you cant see.
  1. New steering wheel control needed SMD conversion gone wrong
    By chuckleuk in forum Electrical & ICE (including SatNav)
    Last Post: 9th November 2011, 21:18
  2. Big problem. Think im stuck wrong part ordered.
    By vxr in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2011, 22:47
  3. Help most definitely needed - locking wheel nut removal gone wrong
    By 1ctchris in forum Suspension, Wheels & Brakes
    Last Post: 29th December 2009, 11:00
  4. Sometimes we actually need an explanation!!
    By Vaux-Man-G in forum Comedy & Humour
    Last Post: 20th November 2009, 18:19
  5. An Explanation
    By VauxVeteran in forum The 'Off Topic' room
    Last Post: 12th February 2009, 10:24
manifold for vectra gsi3.2 2002
