Thread: brake lights stopped working
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    Default brake lights stopped working
    the brake lights on my wifes 04 zafira have stopped working any ideas , how easy or how much thanks.
    Cirencester
    You checked all the bulbs? contacts to bulbs? brake switch? circuit fuses? and if fitted a relay?
    Aug 2007
    Vehicle : ELITE
    Trim : FULL LEATHER
    Mileage : 87,000
    No just noticed tonight when the wife came in its to wet and late now i will check that all out tomorrow
    Regular Member Robbie69's Avatar
    does it have a switch near the pedal? I remember years ago when I had a SAXO (i know but I was only 21 and got it new) it had a switch on the pedal that failed? Not sure on the veccy though but must be similar.
    Regular Member 900ss's Avatar
    May 2008
    Bucks
    Unreal, so have they on my 06 Vectra
    Disconnected then re connected the battery as a cure.
    So far so good but soon see.
    Assuming is not a fuse then brake pedal switch is the next fav for no brake lights
    Aug 2007
    Vehicle : ELITE
    Trim : FULL LEATHER
    Mileage : 87,000
    i will have to try the battery trick ,fuses and bulbs ok i
    havent located the switch yet
    the switch is on the top of the brake pedal, so it latches when the pedal is pushed forward..it's clipped in and has one electrical connector..
    best spotted when you're upside down in the footwell , looking up..
  1. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  2. Dip-Beam Lights - Both stopped working
    By TheMorphiuz in forum Electrical & ICE (including SatNav)
    Last Post: 28th December 2011, 19:17
  3. Right my hid stopped working
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 21st December 2011, 15:22
  4. DAB stopped working
    By sandman1001 in forum Electrical & ICE (including SatNav)
    Last Post: 8th February 2011, 22:27
  5. brake lights stopped working
    By peadar in forum Electrical & ICE (including SatNav)
    Last Post: 13th November 2008, 21:57
