Thread: If I have ESP, could I fit IDS?
    Full Member RichM's Avatar
    Bracknell
    30 Post(s)
    Default If I have ESP, could I fit IDS?
    Hi all,
    I didn't realise when I ordered my Vectra that I could have the IDS+ option Is this something that could be retro fitted at some point in the future? The car has all the other toys so should have a pretty good loom?
    Thanks, Rich
    Regular Member Robbie69's Avatar
    What's IDS? I grew up in Wokingham by the way, live outside Oxford now.
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Interactive Driving System Plus. Fancy name for Electronically controlled dampers, whereby dampers can be selectively adjusted automatically . Something to do with yaw angle compensation and ride height adjustment to minimise body pitch and roll, all way too technical for me. Ian_c's got it on his I500, for one.
    Bracknell
    30 Post(s)
    Quote Originally Posted by john_k_sri View Post
    Would like to fit the whole lot including the dampers, sport button etc. How much work would be involved? This is a bit of a project for the future
    [Ex]Admin Duncan's Avatar
    It'll be £££££££&#163 ; to retro-fit and possibly not even possible. Needs a different steering rack for starters and too many components/looms etc. to mention. Not sure if it'd need a different variant of ECU as well.
    Good luck if you try it, but prepare for obstacles/disappointments/wallet emptying in the process.
    member of the smoke patrol 230bhp+
    there is adaptor for the rack as for the wirring to the shocks it's not there so you need to fit the looms and yar ecu ill take a punt and say the well over the other side of £1000 in bits
    Bracknell
    30 Post(s)
    Yikes, sounds scary for a £450 option. I guess it's easy when the car is being built
    Regular Member Stu14t's Avatar
    Perth, Scotland
    I've got IDS+ and it's great. Does wonders on corners and bumpy roads. Wouldn't like to try and retrofit it there's loads of extra sensors on top of the dampers for startes and I suspect extra looms too as Duncan said, plus a guru on a tech2 would be needed.
    Think Big Pete has it too???
    Bracknell
    30 Post(s)
    Quote Originally Posted by Stu14t View Post
    Alright, don't rub it in If only I'd seen that tick box, didn't think it was an option on the Vectra!!! Used to drive my Astra with the sport button on all the time!
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    95 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Lol... Oh yes, wouldn't be without it now, glad i asked what it was when i ordered the car...!!
https:www.vectra-c.comforumshowthread.php58909-If-I-have-ESP-could-I-fit-IDS
