Thread: Parking Sensor woes
    Larkhall
    Default Parking Sensor woes
    Car came with parking sensors which have been working fine up till last week. When you put the car in reverse they beep once, like all of them do. But mine beep once when reverse is engaged, then beep constantly about a second later. I need to put it out of reverse then back on and they are fine.........
    Anyone got any ideas on what it could be? I'm considering chopping the wires lol
    kirriemuir
    i,ve had the same problem, check for dirt around the middle of the sensors in the groove if no dirt is found press in the middle till you feel the sensor inside move alittle, my thought was the sensor works on sound waves and the sensor needs a little movement and sometimes it sticks
    Just means you're about to hit the wall mate....
    Larkhall
    I thought it could be dirt, but it happens everytime i select reverse when i first switch on the car........
    I'm going to spray them next week so they are colour coded. Hopefully the paint isn't too thick so they won't work
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    Quote Originally Posted by T4M View Post
    Just 2 or 3 light coats will do it, On my cheapo Cisbo kit from Ebay, I noticed that they do have 4 adjustments inside the unit, 1 for each sensor. I sprayed mine and they work fine even in rain. May be worth unplugging each sensor one at a time in case its just the one sensor thats playing up, in which case you can leave just that one unplugged.
    Larkhall
    Quote Originally Posted by Cameron43 View Post
    Cheers mate, will have to try that
  1. Parking sensor
    By CHooper80 in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2010, 14:00
  2. Parking Sensor
    By sshaikh in forum Insignia car chat
    Last Post: 16th November 2009, 11:05
