Results 1 to 10 of 16
Thread: Hot Brake Lights
    Jun 2007
    Black Country
    Default Hot Brake Lights
    Ive replaced 3.........YES 3 !! near side brake lights in as many days, the filaments are all fine, but the base of the bulbs are melting away, The spring thats inside the bulb holder that makes contact with the base of the bulb, is all black and crusty
    Is there a known fault or am I just the lucky one???
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Quote Originally Posted by Guyver1 View Post
    I'm on my 4th bulb in 2 years because of the same reason: bulb not blown but base melted... each time I replace it with a Philips Premium bulb and clean the spring and the inside of the bulb holder, and it holds 5-6 months
    Jun 2007
    Black Country
    I wish mine would last that long
    Surrey
    Your using the middle pedal too much.
    My nearside blew so I replaced it but it wasn't melted. I haven't had the car long enough to know the frequency at which they fail.
    Belgium
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    by the way, I don't think it has something to do with braking... the same bulb is used for the normal rear lights... I would think the reason for heating (and melting) is a bad contact between spring and bulb base during longer periods
    Sunny Dartmoor
    I'd say replacement of the bulb holder would sort out the problem......
    Surrey
    Strange it is only on nearside, water/condensation causing the corrosion?
    Sunny Dartmoor
    Quote Originally Posted by steve1975l View Post
    Could be Steve......
    Jun 2007
    Black Country
    Light unit is bone dry, its only the brake warning that flags up a fault, when the bulb is removed, there is just nothing left on the base,
    what sort of money would we be talking for a new bulb holder??
    Belgium
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    when I asked about it, dealer told me they should replace the whole unit...
  1. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  2. Brake Lights Staying On
    By Bethan39 in forum Electrical & ICE (including SatNav)
    Last Post: 21st December 2012, 11:59
  3. flashing brake lights????
    By mike. in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2012, 10:58
  4. Brake lights staying on.
    By DTI Dave in forum Electrical & ICE (including SatNav)
    Last Post: 7th December 2011, 13:16
  5. rear brake lights
    By jofess in forum Electrical & ICE (including SatNav)
    Last Post: 12th October 2007, 23:42
