Results 1 to 10 of 25
Thread: Wiring in illumination for a boost gauge - can anyone help?
    [Ex]Admin Duncan's Avatar
    Lightbulb Wiring in illumination for a boost gauge - can anyone help?
    Following on from my boost gauge thread, I want to wire the gauge in for the dial illumination. It's a simple pos and neg feed.
    Question I have is that I want it so that the dial only lights up when I turn the headlights on, so the obvious place to tap off the live would be one of the several cables that go into the back of the headlight/fog switch assembly.
    Does anyone know exactly which one of these is the one I need to tap off. Don't want to find that the dial only lights up if I turn on the rear fogs!!
    I can take a pic of the wiring if it helps.
    I assumed that this is the best point to take a feed off - especially as the wiring from the dial drops straight into that part of the rear of the dashboard area. I'm also assuming that tapping into one of these wires isn't going to affect any bulb warning thing as I'm on this side of the headlight - if you see what I mean.
    Ta
    Here, there and every where!
    Does'nt the glovebox lamp only come on with the lights? Might be an easier way to tap into the circuit.
    Quote Originally Posted by Caterman
    I think that comes on with ignition - I'd have to check. Even if it was headlights, I'd have to find the wiring that was the battery side of the glovebox switch. Not sure if that's a bit buried away. Even if I could, I'd then have the run a wire to the drivers side of the dash, and it's awfully cramped behind that centre console!
    I just thought the headlight switch was the obvious place and it's perfectly positioned to where I want to be running cables.
    Anyone? Not that I'm being impatient and trying to get the wiring done today!
    Regular Member Robbieben's Avatar
    Dec 2005
    Polishing a car somewhere
    Duncan if you use a circuit tester to probe the wires at the back of the switch, with sidelights switched on, when u find 12+ volts, usually about 13.4volts, turn off side lights, if no voltage reading from that wire then that is the one to connect to. Make sure that you use sidelights only, if you use dipped beam, gauge will only illuminate when on dipped beam.
    Sweden
    On the Astra G it was easiest to take it from the ashtray/lighter ... but dont know if it will be the same on the Vectra.
    Ah yes, good suggestion TechWolf. Running a wire down there shouldn't be a big deal - I think.
    The headlight switch is definitely closer, but at the same time I'd be more comfortable not splicing into the cable(s) that go into the headlight/fog light switches.
    I'll have a look at that option - thanks.
    BTW - replies still welcome on the headlight switch option!
    Quote Originally Posted by Robbieben
    Ah, thanks Robbie. Not sure if I can get a contact on the wires when they are in the headlight switch - it's a little multiplug thing - but I'll go and double check.
    Dec 2005
    Duncan I use a pin to pierce the wires for testing purposes, the type that you would use to fasten a button hole flower to a suit etc.
    Gently push wire into cable then touch ammeter to pin.
    Once pin is removed rub wire between fingers and hole closes back up.
    Right, good idea. That little hole isn't going to cause a problem and will pretty much close back up.
    I need to refresh myself with the colours of all the cables going into the switch, but I assume it'll be whichever black one is there that I'll be using as the ground?
  1. Boost gauge help!!!!!!!!
    By tomo41 in forum Vectra C / Signum Troubleshooting
    Last Post: 26th June 2011, 17:36
  2. boost gauge wiring up
    By tomo41 in forum Electrical & ICE (including SatNav)
    Last Post: 30th May 2011, 13:13
  3. boost gauge
    By dean_walsh2001 in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2009, 22:04
  4. What exactly does a boost gauge do ?
    By Cerealuk in forum Vectra C / Signum Car Chat
    Last Post: 27th June 2007, 23:08
  5. My boost gauge, little sorry...
    By nutron in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2006, 07:55
wiring boost gauge to headlights astra h vxr
wiring a boost gauge to a zafira headlight
vectra c sidelight switch wire
vectra light switch boost gauge
