Page 1 of 5 123 ... LastLast
Results 1 to 10 of 46
Thread: Signum Aerial Removal
    Maida Vale
    Default Signum Aerial Removal
    Has anyone any experience of removing the aerial base on a Signum? Firstly I'm assuming it unbolts from under the roof after moving the roof lining out of the way - correct? If so, is it feasible to do it with just the rear edge of the roof lining pulled down rather than all of it? I've got the set of 5 or 6 storage boxes in the headlining and it'd be easier if I could leave them and that part of the roof lining in place. If this does sound like a goer, does anyone know how to remove the interior trim from the C-pillar to release the roof lining (do the airbags cause issues?), and does the retractable 3rd seatbelt in the roof cause problems?
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Hi thomas,
    Answer to your first yes it is possible to remove the arial by just pulling down the rear lining no need to remove the trim around the C pillar and the 3rd seatbelt is not an issue except Remove the cover off 3rd seatbelt housing before you pull the lining down and carefully remove foil edge lining to roof lining in the surround (very thin very easy to distort and then a pig to reallign)
    When you pull down the lining fold sellotape over the edge this will stop lining de laminatting while you remove arial .
    Arial is held on by 17 mm nut only, but before removing this unclip wiring connector from its fixing in the roof and pull apart bullet connector by lifting tab .
    Fitting is the reverse there of .
    If your lining delaminates use double sided tape to reshape lining and then place d/sidedtape in between roof and lining to hold in place.
    Maida Vale
    Cheers Bob!
    Regular Member bertbuckie1's Avatar
    Turriff - Aberdeenshire
    bobssignum im away to attempt this, if your there the ariel does had 2 wires in the siggy doesnt it? a black plug one and a live ?
    Engine : 2.0DTi
    Mileage : 73350
    Hi mate as far as i can recall yes two wires
    and still loving it
    dammit, theres 3 coaxals and one smaller single wire..... any ideas ?
    ...i connected 1 coaxal to the ariels coaxial, and the single as well, seems to work so far, not sure about signal yet tho... heres some pics just for fun
    ...also, i tried to test for voltage through the cables but got nothing, is this normal ? ( DC )
    right correction, just went outside but its too dark now, getting 12vdc and 12v live is connected to live on the ariel, i tryed the coaxial into all 3 of the coaxial plugs and only 1 gave any signal at all. its a cack signal, but when i stick a screwdriver into the chopblock connected to the ariel ( not the 12 live ) it gets amazing.....should i just buy a bit of cable and just attach it and leave it above the roof appolstry ?
    ...looks nice tho lol
  1. Signum Shark Fin Aerial (with Nav)
    By bbdp in forum Electrical & ICE (including SatNav)
    Last Post: 3rd March 2014, 13:29
  2. removal of vectrac aerial??
    By rickh01 in forum Bodywork & Interior
    Last Post: 23rd June 2012, 21:39
  3. Anyone ever changed the aerial on a signum?
    By Shogun in forum Styling
    Last Post: 1st September 2011, 23:37
  4. Aerial base removal?
    By Stuarty in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2009, 18:21
  5. Radio Aerial Removal
    By BigMan in forum Electrical & ICE (including SatNav)
    Last Post: 14th January 2008, 19:34
vectra c aerial removal
how to remove vectra c aerial
vectra c aerial base removal
how to remove vectra c rear roof liningHow to remove a vauxhall signum rooth arileremove aerial base vectra chow to remove vectra c aerial basesignum aerialhttps:www.vectra-c.comforumshowthread.php58668-Signum-Aerial-Removalhow to change vectra c aerialsignum aerial basevectra c remove aerialhow to remove aerial from vauxhall vectrahow to re.ove aerial on vectra cvauxhall vectra c aerial removal
