Results 1 to 3 of 3
Thread: Siggy Passenger Side Rear door Pin not releasing
    Jan 2008
    NW - Cheshire
    Default Siggy Passenger Side Rear door Pin not releasing
    I've started having a problem where when I unlock the car the passenger rear door doesn't open, you can see the pin come up about 75% but in order to open the door you need to just pull the remainder up.
    Anyone had the same and is it a easy fix.
    Thanks in advance.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Can't say I've ever had the issue, but it sounds like a lock lubrication issue at first glance.
    Open the door and spray a little WD40 into the lock mechanism and work it in by latching / locking / etc.
    Either that or a door card removal to see why it's not fully operating.
    it could be as simple as the plastic door pin binding in the sleeve in the door trim..
    best way to find out is to remove the trim.. if it works okay, then it's the trim.. if it still sticks it will be the door locks internals... use spray grease as it will creep and penetrate but remain longer than WD..
  1. Passenger side door lock
    By Taxi_G in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2011, 19:54
  2. 17" sri alloys and passenger side rear door
    By jonny22 in forum Parts for sale
    Last Post: 4th October 2009, 17:19
