Results 1 to 10 of 25
Thread: Electric Window Problem
    Hampshire
    Unhappy Electric Window Problem
    Hi all.
    I bought a 02 Reg Vectra C about 3 months ago and since then can only control the windows from the Drivers door panel. It has been into a garage a couple of times and they have now said that they cannot get it to work as the coding on the modules does nto match (what ever that means). All they can do is wait until they get a similar car in and copy the coding from that. They have been on to Vauxhall who have told them the same thing.
    Am I going mad? Surely it should just work?
    Apparently the problem is down to the Passenger door module having the Central Locking and Boot controls onit as well as the Pasenger window control.
    Anyone have any ideas or any similar issues?
    Trev
    [Ex]Admin Duncan's Avatar
    Sounds like complete tosh to me! Coding doesn't match on the modules?!! The likely reason is that the passenger door window switch is knackered/dirty. Often all that is needed is to part disassemble the rocker switch and give it a good squirt with contact cleaner and off you go. Worst case is that they've worn so a new switch is needed.
    Do the unlock buttons on the passenger side work? If they do, that would definitely disprove any 'theory' about 'mismatched coding'.
    Hampshire
    Sorry, probably didn't explain myself very well.
    Only the Driver's door controls work, not Passenger or Back doors. They have told me that the Passenger unit not being recognised is knocking out the back doors as well.
    None of the buttons work (I'm not that bothered about the Central Locking and Boot on the passenger door), only the Driver's door controls.
    Ah, right - that extra info helps.
    It does sound like it could be an issue with a door module then, but exactly what is difficult to say. Not too sure about the coding mismatch thing, but if Plasma sees this thread then he may have some input as he's had a fair bit of experience with them with mods he's done.
    Hampshire
    Thanks, I will wait for Plasma
    Melbourne, Australia
    Quote Originally Posted by TrevF View Post
    Does the switch on the driver's door operate windows on other doors (passenger door/rear doors)?
    Does the remote key lock/unlock the passenger door?
    What about using the remote key to raise and lower the windows - does that work (on all windows)?
    Full Member plasma's Avatar
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    Sorry took me a while to respond.. do as stevedee3 above says and come back with your results, will give us more info to go on. Dunno what they mean by lost the coding? there is firmware on the door module which can be updated. they could have reset it and lost the firmware but their tech2 would be able to put it back on again. also there are variant config options (ie which items you have fitted like folding mirrors, heated glass, etc etc)which can be set/unset but if they've wiped them it will automatically try to copy it from the drivers door module... So not sure on what they've done/lost. The back doors dont work off of the modules (the windows dont at least) at all, they work via the rear electrical centre and body control module so cant see how the passenger door module would stop it working. Get back to us with the results of the tests.
    If you get down to Harry's meet I'll try my utmost to get there and can have a proper look for you and even bring a spare module.
    http://forum.vectra-c.com/showthread.php?t=55727
    trev, i will have a look in my "stash" of vec-c switches and see if i have one for the pass door front 4 u..
    Hampshire
    Quote Originally Posted by stevedee3 View Post
    Thanks for the reply. Here goes: Does the switch on the driver's door operate windows on other doors (passenger door/rear doors)? Yes, this controls all windows, central locking and boot. Does the remote key lock/unlock the passenger door? Yep What about using the remote key to raise and lower the windows - does that work (on all windows)? It does indeed. Hope this helps. Trev
    Hampshire
    Quote Originally Posted by plasma View Post
    Took me a while to catch up too, don't worry, and thanks for taking the time. I've replied to Stevedee3 (above) Based on the what they ahve told me they changed a module on the car before I brought it, this had something to do with the immobiliser not disengaging. They referred to it as an ECU, but based on whaq I have read this may have been the body control module. When I got the car all seemed OK initially, but quite soon (i.e. as soon as my wife got in and tried to open the windows), we found that the Passenger controls did not work. I then tried the rear window sontrols and these did not work either. Some more tests showed that the Alarm, Horn and double locking were not working and the Remote Window control only operated the Driver's window. They took the car back to reprogram it and fixed everything apart from the Window controls. The guy told me that the module did not recognise the passenger door unit. I was then given some speil about there being problems with the ECU (or body control module?) on original Vectra C's and there being some 8 different revisions since then. Apparently in all of these revisions my particular configuration has been lost. They need a similay Vectra to get the coding off of! To me this sounds like a load of tosh, but I'm a computer expert, not a car wiz! Hope this makes some sense to you. Thanks for the offer, very kind of you, but I don't think I'll be able to make the meet. Trev
  1. Rear electric window problem
    By Bloicy 3.2 V6 GSI in forum Electrical & ICE (including SatNav)
    Last Post: 12th September 2011, 12:34
  2. odd vec c problem, electric window
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 22nd April 2011, 00:34
  3. Electric window help
    By manimal in forum Bodywork & Interior
    Last Post: 19th November 2010, 22:10
  4. Front electric window problem
    By James7 in forum Electrical & ICE (including SatNav)
    Last Post: 5th November 2007, 01:52
  5. electric window problem
    By jon ixi in forum Electrical & ICE (including SatNav)
    Last Post: 28th March 2007, 23:23
signum passenger window only works off remote
