Thread: Drivers seat belt after crash
    Regular Member Mark2.2's Avatar
    Feb 2006
    North East Uk
    Default Drivers seat belt after crash
    Does the drivers seat belt give up after the car has been in a crash? I know the pre seat tensioners normally go but it's my drivers side seat belt that's not working on my vec c sri. It's stuck out after the last person was wearing it, it won't retract. I was thinking of taking it off and having a look at it, as it won't pass it's mot not working. My seat belt pre tensioners are fine .
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    only the tensioners mark as they will need to be replaced
    and you will need to get the airbag module tech 2 to remove the crash data if the cant be donr then you will need to send it to http://www.crash-data.co.uk/ as i had to send mine here
    if the belt was worn at the time of the crash the tensioner would of deploded and its worth removeing the belt to see why it not going back . you can always get a second hand one
    Feb 2006
    North East Uk
    Normally when the tensioner goes the yellow tag pops out, it looks fine on mine. I have not worked on a Vec C before, so I was not sure how the seat belt thing worked after a crash. I was thinking of buying a blank airbag module from Ebay and fit the new bags, then take it to Vauxhall to get it cleared.
    when my tensioners went i didn't have ant yellow tags
    if you buy a blank module if will cost you £70 plus what ever vx will charge to chand the data of the car for reprogramming, so it will be cheaper to send your old one of as the charge £60 which includes the returnit as next day delivery
    Feb 2006
    North East Uk
    So you save about £10. Will Vauxhall still have to tech 2 it to remove the airbag fault? I still need a dash and both airbags yet, but that will be the last thing I do. I missed a dash on Ebay the other day for £50 . Cheers
    Regular Member mooney's Avatar
    North west
    Trim : VXR
    Engine : 2.8 v6 turbo
    Year : 06
    only older cars had the tags come out iirc i know the corsa's did
    Regular Member boba's Avatar
    The Kingdom of Fife!
    If the bump was enough to trigger the pretensioners I would be inclined to replace the whole belt. It's not easy to tell what damage there is, it isn't expensive and it may save your life.
    Quote Originally Posted by glynn View Post
    Right!
  1. Slow/Sticky drivers seat belt - how do I release it?
    By Vaux-Man-G in forum Bodywork & Interior
    Last Post: 20th June 2012, 10:37
  2. Drivers seat belt stuck!!! Help
    By degsy1234 in forum Bodywork & Interior
    Last Post: 23rd December 2010, 15:23
  3. Rear seat stuck down due to locked seat belt
    By Brad_The_Yid in forum Bodywork & Interior
    Last Post: 15th May 2010, 13:22
  4. seat belt light and seat occupancy recognition
    By xc600 in forum Electrical & ICE (including SatNav)
    Last Post: 6th May 2010, 20:26
  5. sloppy drivers side seat belt..........
    By david.aka.judas in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2009, 21:12
