Results 1 to 10 of 13
Thread: Click/ light clonk
    Regular Member old cruiser's Avatar
    slough
    Default Click/ light clonk
    Bit of a strange one going on with my motor; park up at work with handbrake on get back into car after work start car and start reversing and after moving a few feet I get this sort of click / light clunky noise, but only once as when I get home I reverse up the drive and there's no noise at all, recently started to leave handbrake off and leave in reverse and seem to be better (not so loud) however today I pulled up, put handbrake on, switched off and realised I put the handbrake on, so let it off and again left it in reverse and tonight it made the noise again on reversing, could it be and is it common on these veccy's for this to happen and could it be that this time as I put the handbrake on in error (as it were!!) that the pads are somewhat sticking to the discs as they were hot this morning? Incidently nothing seems to be amiss under there last time I looked.
    P.S sorry to rant On!!
    Cheers Pete
    sounds like the pads are holding on... a strip and clean/grease up may help out no end....
    You using VX pads or patterns parts..
    Jul 2006
    Mexico
    Yeah it happened to me a pair of times...seems that for some reason the back pads stick to the disk...why..not a clue.
    slough
    Eek
    I think you're right mate a strip and clean, I believe them to be genuine VX pads as previous owner always had VX doing his servicing, did hear somewhere about some modified rear pads that have a top spring of some sorts, have you heard of this youself?
    The more I think about this I hope it is just to do with the pads and nothing else making this noise as it is a bit hard to hear exactly where it's coming from!! but seems to be handbrake related ; I hope I'm not getting paranoid!! certainly don't want to go down that route!!!
    yep, there is a new design of pads....
    and the rear pads are used by the handbrake so the two could very well be related..
    slough
    Cheers mate , I'll have to look into that
    Cheers Pete
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    i had this problem but when i changed the pad it went away
    slough
    Quote Originally Posted by Danwells72 View Post
    I take it you fitted the modified pads?
    Cheers Pete
    Jul 2006
    Northampton
    Trim : Sri
    nope just normal pads
    slough
    Interesting!
    Cheers Pete
  1. Strange clonk from front end
    By KevinG in forum Suspension, Wheels & Brakes
    Last Post: 19th December 2011, 20:31
  2. Clonk/click on steering wheel
    By s2yob in forum Vectra C / Signum Car Chat
    Last Post: 7th July 2011, 19:50
  3. click click click driveing me mad!
    By bangty 1 in forum Engine & Drivetrain
    Last Post: 3rd May 2011, 20:10
  4. re clonk
    By solorider in forum Vectra C / Signum Car Chat
    Last Post: 9th March 2009, 17:35
  5. ball joint type of clonk on suspension
    By andy.l in forum Suspension, Wheels & Brakes
    Last Post: 22nd October 2007, 12:56
