Thread: Exhaust Gas warning light on a diesel?
    Preston
    Default Exhaust Gas warning light on a diesel?
    Hi guys,
    My 2004 2.0 Dti shows the warning light (car with a spanner through it) quite regulalrly sometimes for 10 seconds, sometimes for 10 minutes but always goes out if I resart the car. I have noticed it happens more often when coasting or after accelerating for long periods. Others have posted about Lambda sensor problems which I am guessing I am also suffering from. I still get excellent MPG although am I a little disapointted with lack of pull below 2000rpm. The light comes on for an average of 2 to 3 mins on an hours journey.
    Question is will there be much of a problem leaving this like it is and 'ignoring' the light, and what are the implications to cat etc if left unattended to?
    Cheers guys and gals!
    James
    West
    Get the fault codes read & work from there!
    A couple of common faults on the egr side of things are splits in the vac tube connectors, coked up egr or faulty vac pumps.
    it's always best to get it code read before going off chasing other folks theories..it could be anything from a dodgy boost pressure sensor that needs a clean to a dodgy EGR...
    best get it read out..
    Regular Member addyboy1982's Avatar
    Northampton
    Mine does this too, you ought to get it booked in just to see what it is - I'm booking mine in when I get time to go out of work to the dealers.
    Preston
    sounds good addyboy. Please post here if you find anything intresting. I don't think that the codes are being stored on my car as the warning light does not illuminate at ignition....any thoughts?
    James
  1. Exhaust gases warning light
    By CH-VECTRA-ELITE in forum Vectra C / Signum Car Chat
    Last Post: 5th July 2011, 12:01
  2. exhaust gases warning light has come on..
    By dog in forum Vectra C / Signum Car Chat
    Last Post: 12th April 2011, 13:50
  3. Vectra 2.0 Diesel engine warning light
    By Biggus Shlongus in forum Vectra C / Signum Car Chat
    Last Post: 7th September 2009, 19:11
  4. Exhaust Gas Warning Light On!
    By doncaster_mainline in forum Vectra C / Signum Car Chat
    Last Post: 1st December 2008, 20:45
  5. Exhaust gases warning light!
    By eashton in forum Engine & Drivetrain
    Last Post: 30th September 2008, 10:44
