Thread: Permanent live issues
    Regular Member martinbruce's Avatar
    Wales
    Default Permanent live issues
    Hi all,
    Got a slight problem with the ignition live.
    I have tried swapping red and yellow wires around, that didn't work.
    If I, (as someone in another thread mentioned) connect the red and yellow wires together and plug it in to the permanent live it all works OK. but I can't switch the radio off! It stays on when the key is out, even with the face off, it still continues to play whatever you had on. eg. radio, dvd...etc
    If I connect the two wires and plug it in to the other live (when you turn the key, it becomes live) where the yellow wire is supposed to go and turn the key nothing!! I really cant understand that, it just doesn't make sense??
    I have popped a multi-meter across it the, permanent live has 12.2v and the ignition live when key is turned has 11.5v (is this the problem perhaps)??
    The manual says 10.6v to 15v, so can't see it being that...
    Any help advise would be greatly appreciated.
    Chris Gettings, kindly offered to fit this for me last week, but after looking through the posts and seeing that it was just a matter of connecting the ISO's together, I thought I'd give it a go!!
    M
    Surrey
    You need to get the switched from the ciggy lighter.
    Wales
    Cheers Steve,
    Will give it a go.
    Report back soon.
    M
    Wales
    Yep, worked like a dream. Will try and get some piccy's up later on today.
    Regular Member Dippy-Vx-line Red's Avatar
    Earlston (Scottish Borders)
    Hi..Instaled an after market head unit the other day.It all works fine by taking a live feed from the ciggy lighter..I was wondering if it is possible to get the stereo to turn on without having all the dash lights and fan coming on....I own a 57 plate vectra....?????
  1. permanent 12v live
    By rockafella8587 in forum Electrical & ICE (including SatNav)
    Last Post: 28th December 2012, 17:53
  2. Wiring an amp, need an ignition live and permanent live in the boot
    By inchy1981 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2012, 16:36
  3. permanent live in the boot
    By Al 22 dti in forum Electrical & ICE (including SatNav)
    Last Post: 2nd June 2011, 07:02
  4. permanent live to cig lighters
    By signum stew in forum Electrical & ICE (including SatNav)
    Last Post: 8th July 2009, 22:50
  5. permanent live
    By lizard in forum Electrical & ICE (including SatNav)
    Last Post: 17th October 2008, 16:25
