Results 1 to 10 of 14
Thread: light on dash
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    Default light on dash
    hi all just went to take little one school and as i started the car a light appeared on the dash. it was yellow, looked similar to a can with wavey lines in it?? but when i come back from school it didnt come on cant find a pic is there a thread on here with all the symbols on? or does anyone know what it is? tia
    Regular Member neilshaw1980's Avatar
    Oct 2006
    coventry
    sounds like its the coolant warning sign
    Regular Member LJ sxi-nav's Avatar
    Winchester
    coolant level warning light???
    At work now so can't upload any pics of what it looks like...
    Feb 2007
    not very mechanically minded!! do i just fill it up with water???
    Oct 2006
    coventry
    If its not come on again just visually check the levels on the tank. Mine did this a few times but the level was fine
    Surrey
    Isn't it because it is getting cold outside and the level dropped a bit more so the light came on. I would check the level when cold, it may just need a drop of water.
    if the level is fine it will be just a dodgy sender unit..buy a new header tank and it will cure that..
    Don't top up with just neat water.... always to up with 50/50 coolant mix or you weaken the strenght..
    Surrey
    I suspect it is a slightly low level hence the light went out when warm. You will only need to put small amount of water in so no real need for more coolant.
    Maida Vale
    This is the coolant level warning symbol...can't say I'd describe it as "a can with wavey lines in it"..
    Surrey
    Thats the coolant fluid level warning. How about a square with bumps in it?
  1. Light on dash
    By topline in forum Electrical & ICE (including SatNav)
    Last Post: 3rd August 2012, 13:00
  2. light on dash
    By kgb in forum Engine & Drivetrain
    Last Post: 27th January 2011, 21:05
  3. Light on on dash what should i do?
    By aerodynamic18 in forum Vectra C / Signum Car Chat
    Last Post: 3rd January 2009, 12:54
  4. Light on dash...
    By dankidd in forum Engine & Drivetrain
    Last Post: 17th December 2008, 01:13
