Results 1 to 10 of 13
Thread: oil warning light
    haworth
    Default oil warning light
    the oil warning light in the bottom left of instrument panel does not light when the ignition is switched on, any ideas please, i`ve changed the oil & filter today so all is well there, could it be a sensor? thanks
    haworth
    oops, its a 1.8 `02 xsi,
    Maida Vale
    One possibility is that someone removed the LED for that warning light if it wouldn't extinguish by itself.... also known as the "car trader fix"...
    check the oil pressure sensor, located on the oli pump behind the front pulley..if the wire is connected i'd change the sensor..
    EVERYWHERE
    What's an "oli pump" ?
    a dyslexic oil pump.....
    you tried being dyslexic recently?..
    haworth
    thanks, i`ll do a check on the sensor & keep my fingers crossed, i`ll keep you informed
    Surrey
    If the sensor was faulty wouldn't it light up on ignition 3?
    not always... depends on how the internal diaphragm has failed..
    normally if it doesn't light it's disconnected..
    Surrey
    Is the wire grounded to light up?
  1. Warning Light
    By chrissy white85 in forum Vectra C / Signum Troubleshooting
    Last Post: 17th December 2012, 18:01
  2. Brake Light Warning Light
    By michaelangelo in forum Electrical & ICE (including SatNav)
    Last Post: 29th August 2011, 01:31
  3. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  4. Oil Warning Light
    By siz1 in forum Engine & Drivetrain
    Last Post: 26th November 2008, 20:03
  5. arghh side light problems warning light
    By Gregg in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2008, 21:58
